FM Forums | Forum & miscellaneous | Join Image Upload
Kid_Film
Image Upload: Off
p.1 #1 · Picture Frame Glass
I'm going to be building some of my own frames and i need some glass. The only thing is i'm not sure what type of glass to get and where i could get it in bulk. Any suggestions?
Thanks
Sep 04, 2008 at 10:51 PM
Mickey
Buy and Sell: On
p.1 #2 · Picture Frame Glass
Go the a glass shop , order up single strength glass (1/16" thick) and cut your own sizes. You might want to consider non-glare.
Sep 04, 2008 at 10:58 PM
jjlphoto
Image Upload: On
p.1 #3 · Picture Frame Glass
If you go to an art supply house, Tru-Vue by Apogee is the popular brand. You can buy it by the case, 6 pieces of 32"x40". (Careful, a case is very, very heavy)
There are several styles including Clear, UV Coating, Non-Glare (has a matte-like tooth to it), Anti-Reflective (has a coating and any glare has a purplish tinge just like a camera lens.)
A-R is very pricey. Non-Glare mushes out the image too munch IMO. For general stuff, I use the clear. UV if I have a bigger budget.
Sep 05, 2008 at 01:30 PM
Trout Guy
Image Upload: On
p.1 #4 · Picture Frame Glass
You can buy Tru-Vue by the case in all the popular sizes. Glass comes 50sf to the case no matter what the pre-cut size is. 8x10-11x14-16x20-20x24-32x40 etc. As an example and if you make correct cuts one lite of 32x40 cuts down to 4x 16x20; one lite of 16x20 cuts down to 4x 8x10....you get the picture.
We are custom picture framers and use Tru-Vue exclusively; standard, UV inhibiting, glare resistant etc. One thing to consider when using glare resistant.....the further your print is from the glass the more out of focus looking it will become. We regularly single or even double mat under glare resistant glass but triple matting keeps the print too far away so double mat is the limit.
Hope this helps you.
TG
Sep 05, 2008 at 02:09 PM
Rob-Bob
Image Upload: On
p.1 #5 · Picture Frame Glass
Second vote for non-glare--
I did several 13x19, mated & framed out to 18x24.
I made them from frame "kits" bought locally without glass. Then I went to a local glass shop and had them order, and cut me some 1/8" sheets.
After everything was said and done, I SUR wish that I would of opted for the glare resistant instead of the regular type. The reflections are horrid.
I will NOT do that again, and strongly reccomend the same for you.
Bob
Edited on Sep 05, 2008 at 03:46 PM
Sep 05, 2008 at 03:45 PM
Lost password?
