2 end
Archive 2008 · 85mm f 1.2 MKII not sharp
mordicai
p.1 #1 · 85mm f 1.2 MKII not sharp
I have a four month old MKII that just will not produce a nice sharp, crisp image on par with my other L lenses. Not at 1.2,2.8 or f4. It does not seem to be front or rear focusing. Its just soft. Do you think this is some thing Canon can fix or do I just have a bum lens?
Aug 22, 2008 at 12:19 AM
Jimmy Ho
p.1 #2 · 85mm f 1.2 MKII not sharp
are you using focus + recompose or specific focal points?
Aug 22, 2008 at 12:31 AM
mark petri
p.1 #3 · 85mm f 1.2 MKII not sharp
an full image along with exif data may go a long way to help answer.
Aug 22, 2008 at 12:39 AM
timnosenzo
p.1 #4 · 85mm f 1.2 MKII not sharp
Post an example....
Aug 22, 2008 at 01:10 AM
Mike1
p.1 #5 · 85mm f 1.2 MKII not sharp
It's usually user error... Crazy shallow DOF requires VERY steady hands. Try to do the same with MF & a tripod to compare against the AF on the same tripod. Make sure that you're using a remote cord or a timer and that you and/or your subject do not move. The 85 f1.2 has a bit of a learning curve to master.
Edited on Aug 22, 2008 at 01:13 AM
Aug 22, 2008 at 01:11 AM
Daan B
p.1 #6 · 85mm f 1.2 MKII not sharp
If it is not sharp at f/4 you really have a problem
Having said that... Is MF giving you the same results as AF? On what cameras do you use the lens?
Aug 22, 2008 at 11:45 AM
Alistair Watson
p.1 #7 · 85mm f 1.2 MKII not sharp
Agreed, posting an image with EXIF will really help.
Aug 22, 2008 at 11:47 AM
cgi_photo
p.1 #8 · 85mm f 1.2 MKII not sharp
camera? is it soft with any camera, work other lenses fine on the body, also soft on a tripod?
since I am a "shaky" guy ;-) I try to have a shutter speed of 1/100 or better (1/160 is ok for me). below that I use a tripod.
Keep in mind the DOF at apertures of 1.2 to 4.0 is veeery thin... how do you focus? do you move your camera after focusing?
without examples and exifs it's hard to tell....
send it to Canon for calibration that's all I can say without images and further informations.
Aug 22, 2008 at 12:44 PM
itsskin
p.1 #9 · 85mm f 1.2 MKII not sharp
Post the pics
Aug 22, 2008 at 02:05 PM
mordicai
p.1 #10 · 85mm f 1.2 MKII not sharp
Let me take a couple of days to do a good photo evaluation and then I'll post the results here for a more informative example. Thank you for you replys........Max
Aug 22, 2008 at 03:18 PM
rhorta
p.1 #11 · 85mm f 1.2 MKII not sharp
EF85/1.2 should be sharp even wide open, at least in the center. Even a little stopped down in becomes razor sharp in the center.
Aug 22, 2008 at 05:08 PM
recordproducti
p.1 #12 · 85mm f 1.2 MKII not sharp
My 85L II is razor sharp, even at f/1.2
I tend to use in servo mode and get a very high keeper rate.
Aug 22, 2008 at 10:27 PM
Dawei Ye
p.1 #13 · 85mm f 1.2 MKII not sharp
The biggest barriers to sharp photos for me is motion and dof and the noise from high ISO that I usually use in conjunction with the lens
On Tripod at ISO 100, the sharpness is amazing Not tack sharp like it is stopped down but still "sharp" (in my opinion)
I hope it all works out, although my keep rate is really low it's the most fun lens I have to shoot with, it just oozes class
Aug 23, 2008 at 03:05 AM
hhski
p.1 #14 · 85mm f 1.2 MKII not sharp
When testing use a tripod. The only way to eliminate movement out of the focal plane.
Aug 23, 2008 at 05:00 PM
Yakim Peled
p.1 #15 · 85mm f 1.2 MKII not sharp
Have you tested it in any way to eliminate the possibility of user error?
BTW, here is my experience with a 35/1.4 which was "not sharp".
http://www.fredmiranda.com/forum/topic/607298
Happy shooting,
Yakim.
Aug 23, 2008 at 05:31 PM
danmitchell
p.1 #16 · 85mm f 1.2 MKII not sharp
Post a sample. There are many things that could be going on: technique, unrealistic expectations, front/back focusing, etc.
If it really is out of adjustment Canon can fix it. If the issue is something else there may be other remedies.
Aug 23, 2008 at 05:35 PM
rhorta
p.1 #17 · 85mm f 1.2 MKII not sharp
I think the problem with these very fast primes is that many people want to use it wide open all the time, even when they are so close to their subject that they end up with too narrow a dof. If you find yourself being challenged by the dof, either back up, or stop down. Some will disagree, but these primes are not about shooting only wide open.
Ruy
Edited on Aug 24, 2008 at 09:32 AM
Aug 23, 2008 at 05:58 PM
SoundHound
p.1 #18 · 85mm f 1.2 MKII not sharp
There is difference between sharp optics and OOF AF. When I shoot people at F1.2/1.4 I only expect one eye in focus (must use MF for glassess wearers for get focus on a pupil). I shoot bursts of shots and either rock my body or the MF.
Aug 25, 2008 at 05:32 PM
DoubleNegative
p.1 #19 · 85mm f 1.2 MKII not sharp
Do NOT focus and recompose, especially wider open. You will be disappointed. Select your AF point specifically. Also realize that at f/1.2 the DoF is ridiculously thin. Finally, this lens is sharp from wide open all the way down; if yours isn't in light of the above, get it fixed.
Aug 25, 2008 at 08:58 PM
RGS65
p.1 #20 · 85mm f 1.2 MKII not sharp
Doesn't this answer the question
Aug 25, 2008 at 09:15 PM
pawlowski6132
p.1 #21 · 85mm f 1.2 MKII not sharp
I did a little experiment tonight. Had my 85 L on a tripod with spot metering at 200 ISO. I did my experiment a little differently though. I took a shot using AF (center focus point on the middle of the label) and then another shot using Live View and MF. One thing I found out is that in Live View, the exposure was much better. Look at the shuter speed!! What's up??
I shot 1.2, 1.4, 1.6, 1.8 and 2.0
In all series Shot A is with AF, Shot B is Live View with MF.
Edited by pawlowski6132 on Aug 25, 2008 at 09:37 PM GMT
Edited by pawlowski6132 on Aug 26, 2008 at 10:08 AM GMT
Edited on Aug 26, 2008 at 03:08 PM
Aug 26, 2008 at 02:24 AM
pawlowski6132
p.1 #22 · 85mm f 1.2 MKII not sharp
1.2
  Canon EOS 40D    85 mm    f/1.2    1/400 sec    200 ISO    0.0 EV
  Canon EOS 40D    85 mm    f/1.2    1/160 sec    200 ISO    0.0 EV
Aug 26, 2008 at 02:31 AM
pawlowski6132
p.1 #23 · 85mm f 1.2 MKII not sharp
1.4
  Canon EOS 40D    85 mm    f/1.4    1/250 sec    200 ISO    0.0 EV
  Canon EOS 40D    85 mm    f/1.4    1/125 sec    200 ISO    0.0 EV
Aug 26, 2008 at 02:32 AM
pawlowski6132
p.1 #24 · 85mm f 1.2 MKII not sharp
1.6
  Canon EOS 40D    85 mm    f/1.6    1/200 sec    200 ISO    0.0 EV
  Canon EOS 40D    85 mm    f/1.6    1/100 sec    200 ISO    0.0 EV
Aug 26, 2008 at 02:33 AM
pawlowski6132
p.1 #25 · 85mm f 1.2 MKII not sharp
1.8
  Canon EOS 40D    85 mm    f/1.8    1/200 sec    200 ISO    0.0 EV
  Canon EOS 40D    85 mm    f/1.8    1/80 sec    200 ISO    0.0 EV
Aug 26, 2008 at 02:34 AM
2 end
