Daan B Offline Image Upload: Off
p.1 #8 · 1Ds3 + 24-70L: Micro Adjustment | |
stanj wrote:
skid00skid00 wrote:
Search spherical field of focus.
While true, and while only very very few lenses are planar field, the vast majority of lenses are sufficiently planar field so that this doesn't come up. After all, the AF sensor points are neatly packed around the center of the frame.
While I agree with you, I still find the 24-70L "walks away" pretty quickly when leaving the center. More so than any other lens I own. When I use a MA of +4, all of the center AF points work good at f/2.8 (from 24mm to 70mm). But under 50mm, the most outer AF points only give good results at appr. f/4 and smaller.
