Andre Labonte Offline Image Upload: Off
panos.v wrote:
Andre Labonte wrote:
molson wrote:
panos.v wrote:
It also depends on the lens.
That's correct, diffraction is a characteristic of the lens, not the sensor.
Diffraction is a function of aperture not focal length. If there is lens dependence, then that means there is something else in the optics causing an issue (i.e. perfect optics are diffraction limited). And, diffraction issues most definitely depends on the sensor. Optics 101.
The bigger the sensor the later diffraction has effect. The same lens will be diffraction limited at a smaller aperture in a bigger sensor. I think the accepted result is that FX has a one stop advantage over DX for diffraction. So if your image becomes smooth mash at f/11 on your D300, it will still be chunky mashed potatoes on the D3 and will be back to smooth mash at f/16.
Furthermore, different lenses have slightly different diffraction limits, depending on their design, after all, they're not all equally sharp to begin with.
That is correct. For a given Mega-pixel value, sensor size matters because of its effect on pixel size. Ultimately, it is the size of the pixels. You will start to see the effects of diffraction sooner with smaller pixels. So while smaller pixels for a given format (i.e. more MP) provide greater resolution, that greater resolution can only be realized if the chosen aperture (actually it's f-stop) can support that resolution. This of course assumes a print size that allows you to see the effects as well.
As for the effects of lenses, again, if the lenses are not diffraction limited, the lens will matter. Most lenses are not diffraction limited, though some of the new lenses are approaching that limit.
My table assumes diffraction limited optics.
Edited on Jul 17, 2008 at 03:01 PM
