2 3 end
Archive 2008 · weekend kit suggestion - airshow and static display
D300
p.1 #1 · weekend kit suggestion - airshow and static display
Hi guys,
im going for a military event this weekend and it promises to have some static displays as well as an aerial airshow.
i'd like to bring just an extra lens as i dont want to carry it all day. want to travel as light as possible. any suggestions on my kit for the D300?
i have:
Nikkor 10.5mm Fisheye f2.8
Nikkor 50mm f1.4
Nikkor 12-24mm f4
Nikkor 17-55mm f2.8
Nikkor 24-70mm f2.8
Nikkor 70-200mm f2.8
I am thinking of these combo:
1. D300 with 12-24mm for wide angle + 24-70mm - medium coverage
2. D300 with 10.5mm fish eye and 17-55mm (really light weight kit) - but no to airshow....
3. D300 with 12-24 for wide angle and the 70-200mm - heaviest, but covers all i need. very tempted to go with this one, but the 70-200 is heavy for a full day...
any suggestions? just one camera + lens, and another extra lens.
thanks all.
Jun 12, 2008 at 11:12 PM
Avi B
p.1 #2 · weekend kit suggestion - airshow and static display
I'd go with 12-24 + 70-200.
12-24 for static stuff (you really do need wide here!) and 70-200 for some flying shots (tho 200 is too short even with the DX crop).
Jun 12, 2008 at 11:14 PM
D300
p.1 #3 · weekend kit suggestion - airshow and static display
you dont recommend a fish eye for such occasions? pointless i reckond? but might get some artistic shots....
tempted to bring the 70-200 but its a lugful ....
Jun 12, 2008 at 11:52 PM
Chris Noyes
p.1 #4 · weekend kit suggestion - airshow and static display
+1
Jun 12, 2008 at 11:56 PM
NightOwl Cat
p.1 #5 · weekend kit suggestion - airshow and static display
I used a 20mm for museum displays, where planes are tucked in tightly and there's not a lot of room to back up without hitting another plane. The Valkyrie didn't fit no matter how far back I got, and I was against the wall. Fisheye should be light enough to tuck in if you choose, but definitely take the 70-200 if you're looking to catch fighters showing off their best stuff.
Jun 13, 2008 at 01:10 AM
Steve Carlton
p.1 #6 · weekend kit suggestion - airshow and static display
Looks like you need an 18-200VR.
Jun 13, 2008 at 01:38 AM
Avi B
p.1 #7 · weekend kit suggestion - airshow and static display
Ever been to an airshow?
So you want wiiide because the planes on the ground are pretty well stacked and you can't back up that much
And you want birding-style focal lengths for the air part of the airshow because the planes are faaar from you! And 200mm just doesn't cut it most of the time. Think 500mm (cheapest way to get there is 300mm F4 + 1.7TC). Or I was thinking the 70-300VR may be a good option here.
Infact, I am going to an airshow this very weekend and am having trouble finding a 300 F4 to rent here in Toronto. I can get the 300 F2.8, but I dont want to lug that around (the 70-200 F2.8 is very light comparatively).
Jun 13, 2008 at 03:35 AM
galenapass
p.1 #8 · weekend kit suggestion - airshow and static display
Good advice. Although I have a 500mm I usually go with my 300 f4 IS + 1.4TC on a crop camera.
I agree a 70-200mm will probably be too short.
Please excuse the dust on the sensor (above)!
Edited on Jun 13, 2008 at 04:01 AM
Jun 13, 2008 at 03:59 AM
gugs
p.1 #9 · weekend kit suggestion - airshow and static display
for an airshow, you will indeed need a very short and a very long lens...
the fisheye could be fun (light and small so no issue)
I would take the 12-24 too
the 70-200 is much too short, add a TC (minimum 1.7) or try to find a 80-400VR or a Sigma 50-500 (Bigma), a much more useful lens for flying planes...
Jun 13, 2008 at 05:45 AM
Rodolfo Paiz
p.1 #10 · weekend kit suggestion - airshow and static display
I'd take the 17-55 and the 70-200, plus I'd invest in the TC-17EII (1.7x) teleconverter which will give you a 120-340/4.8 VR lens. That will at least get you in the game and let you have some fun. You won't capture the same level of quality and detail on the ground-to-air images as will others with 400- or 500-mm lenses, but you will get some beautiful images if you use your equipment well.
Yes, those lenses are heavier. Honestly... get used to it, do a little light weights and use that lens a lot. Over time, you get used to anything. Then, when you try out Nikon's wonderful 200-400 f/4 VR lens (7.2 lbs and my absolute favorite), or a 400/2.8 prime lens (10 lbs of screaming-fast focus and images so sharp they'll cut you), the 70-200 will seem like a child's plaything to the new you.
Check out the "Mustangs Air-to-Air" thread in the Still Life forum if you like airplanes, airshows, or anything that flies. We have a wonderful community of people in that one thread, and some images that will simply blow your mind. Lots of help and tutoring, too.
One big hint on technique: fastest shutter speed you can get on the jets, but slow down to 1/160 or slower for the propeller-driven planes, and pan the camera along with the airplane so you get the airplane sharp as you track it, but you allow enough time for the propeller to rotate and show some motion blur. Planes with stopped props look unrealistic and silly, since everyone knows that's not how they look in real life.
Jun 13, 2008 at 07:10 AM
Rodolfo Paiz
p.1 #11 · weekend kit suggestion - airshow and static display
P.S. This kind of question is a pleasure to answer: it has depth, detail, richness, and enough "personalization" to make it easy for lots of people to provide their answers and opinions for your specific needs and thoughts.
Clearly, you are listening to and learning from the suggestions of others on how to improve both your photography and your forum-ography.
Bravo.
Jun 13, 2008 at 07:12 AM
D300
p.1 #12 · weekend kit suggestion - airshow and static display
thank you guys. i am learning each day from your learned opinions.
yes, i do notice that prop planes definately need to show motion in the air and a slightly slow shutter speed would do the trick. it will be a challenge and i'll try to post some photos up after sunday.
actually it is a military fair with both military vehicles as well as an airshow. im aiming for the Royal Air Tattoo as well, but time might not permit as i have another trip planned.
would you guys prefer me to post photos taken here, or to post photos on the other sub-photography or critique forums?
Jun 13, 2008 at 08:37 AM
D300
p.1 #13 · weekend kit suggestion - airshow and static display
ps:
guys, im not sure to about the suggestion on the 17-55mm or to go with the 24-70mm.
however, i am more inclined, after reading today's post, to bring the 12-24mm and 70-200mm. but not sure if i should bring the 10.5mm fish eye along... i will need to work on the panning technique then!
Jun 13, 2008 at 08:43 AM
panos.v
p.1 #14 · weekend kit suggestion - airshow and static display
What I'd do is bring the 12-24 and the 10.5. The 10.5 is so small you won't even know it's there. Then I'd rent something like a 400 or 500 lens for the day and get some nice shots.
Or bring the 70-200 and buy/rent a 1.7 TC.
Or just bring the 70-200 and crop. You've got plenty of pixels in the D300
Jun 13, 2008 at 10:11 AM
stompyq
p.1 #15 · weekend kit suggestion - airshow and static display
I'll be running in to a similar situation next month. So thanks. Didn't know that i needed a really long lens.
Jun 13, 2008 at 10:49 AM
BenV
p.1 #16 · weekend kit suggestion - airshow and static display
+1
+2
Jun 13, 2008 at 02:57 PM
cbrandt
p.1 #17 · weekend kit suggestion - airshow and static display
BenV wrote:
+1
+2
+3
Jun 13, 2008 at 03:25 PM
cbrandt
p.1 #18 · weekend kit suggestion - airshow and static display
oh ....... and I'd slip over to the City, Still Life and Abstract forum and check out the beautiful plane photos there for some composition ideas ......
Mustang Air to Air " The Sequel ........
Jun 13, 2008 at 03:28 PM
Alan Louie
p.1 #19 · weekend kit suggestion - airshow and static display
I mostly shoot between the 12-24 wide and the 70-200 sometimes with a 1.4x TC on it (depending on where i'm standing vs the center of action).
Things are either really close... or really far. So I vote #3. And there's enough time between the planes flying to take a break and sit down, the 70-200 isn't that bad Maybe taking a tripod/monopod to simply rest it on between shots would help? (definately taking it off when you're going to start shooting)
Jun 13, 2008 at 03:34 PM
Rodolfo Paiz
p.1 #20 · weekend kit suggestion - airshow and static display
I'd caution users without prior experience with longer lenses not to try a 400mm lens just for a day. For someone whose longest lens is a 70-200, the very narrow field of view is disconcerting at first, makes acquiring and tracking subjects a large challenge, and likely introduces lots of vibration as the left arm attempts to hold that ten-pound lens out front. The percentage is "keeper" shots is going to be really, really low.
I was that shooter only two years ago, and I still remember how hard it was to make the initial adjustment. And I had two things to make it easier: the 200-400 can zoom out and make focus tracking and acquisition easier, and it's only seven pounds, not ten. For a newbie, all of these things are a shock.
If someone is renting a long lens (200-400, 400, 500) for an airshow, I'd advise that you rent it at least for a week and take that opportunity to really give yourself an "intro" to long lenses. Shoot it as much as you can that week. Handheld, on a monopod, on a tripod, everywhere. You're going to need all the practice you can get. Then, once you get used to them, they're great fun and not a big deal... it's just the initial shock.
Jun 13, 2008 at 03:42 PM
poisonpill
p.1 #21 · weekend kit suggestion - airshow and static display
For the future, I think the 50-500mm Sigma is one of the best casual airshow lenses. A monopod would help that too methinks.
Jun 13, 2008 at 04:05 PM
Andre Labonte
p.1 #22 · weekend kit suggestion - airshow and static display
Bravo.
+1 And well said Rodolfo.
Andre Labonte
p.1 #23 · weekend kit suggestion - airshow and static display
cbrandt wrote:
BenV wrote:
+1
+2
+3
+4 Definitely add the 1.7TC. Also Rodolfo has a point about experience with lenses longer than 400mm on a DX format body. Get the 1.7TC and get used to it on the 70-200. Once you master that, go for longer. Also, consider a monopod if you are going to be shooting planes in the air for more than 30 min.
Jun 13, 2008 at 04:07 PM
D300
p.1 #24 · weekend kit suggestion - airshow and static display
i agree with rodolfo, that the 70-200 or more causes a very narrow field of view and that makes tracking subjects a large challenge - more so during an air show. I tried it with an old nikon 28-200mm on a D70s before and it was really really tough and it didnt have any VR and most shots came out blur. the 70-200VR is heavy too!
Jun 13, 2008 at 05:59 PM
Avi B
p.1 #25 · weekend kit suggestion - airshow and static display
Nah, the blurryness is due to not having enough shutterspeed or it not being focussed. The 70-200VR is not really *that* heavy. You should try a 300 f/2.8 on for size
Jun 13, 2008 at 06:49 PM
2 3 end
