antacid Offline Upload & Sell: Off
to help with the water droplets on the front port, you have a couple of options.
1. spit on it, rub it around, then rinse it off
2. put a little soap (bio-degradable, i hope), rub it in, then rinse it off. johnson & johnson baby shampoo works great, and smells even better.
3. Rub in some toothpaste on the port, leave it to dry overnight, then wash off the toothpaste.
4. rub some raw potato on the port, then rinse it off
5. rub some apple slices on the port, then rinse it off
these are tricks that underwater photographers use to get over/underwater shots with wide-lenses.
personally i prefer method #1, but it's tough when you need to spit all over an 8inch diameter glass dome port! plus its cheap and does not require any additional preparations.
oh, try not to use your hand to wipe off the water, because the oils on your fingers will cause smudging. also never use RainX on the port or it'll cause irreparable scarring.
Edited on Jun 10, 2008 at 03:17 PM
