Archive 2008 · Impressive BH-25LR and Gorillapod SLR performance
Yakim Peled
p.1 #1 · Impressive BH-25LR and Gorillapod SLR performance
I was confined to my home (babysitting my young son) and was bored. As I had both available, I thought I'd play a little.
40D is 740g. BG-E2N is 280g. 70-200/2.8 IS is 1600g. Kenko Pro 2X is 185g. RRS L plate for the 40D + grip is 130g. RRS MPR 113 is 55g. Total is 2990g. That's a practical 3Kg.
BH-25 LR is up to max 4Kg. So far, so good. But the Gorillapod SLR is only up to 2.7Kg. Also, a 400mm lens (effective 640mm) is, I'm sure, not exactly what the manufactures had in mind when designing them.
I used LV as a sort of MLU and a 10 seconds delay. Shot in JPEG.
Happy shooting,
Yakim.
May 24, 2008 at 07:23 AM
Yakim Peled
p.1 #2 · Impressive BH-25LR and Gorillapod SLR performance
I tried to make it difficult. In order to achieve maximum exposure time I lowered the ISO to minimum (ISO 100), closed the lens to the minimum without encountering diffraction (f/22) and used the maximum focal length I had (200mm lens and 2X TC). Resulting exposure time was 1 second.
Don't know what about you but I think it is very impassive.
Happy shooting,
Yakim.
Edited on May 24, 2008 at 07:35 AM
Jman13
p.1 #3 · Impressive BH-25LR and Gorillapod SLR performance
Definitely not bad. How does the gorillapod hold that rig when wrapped around a railing?
May 24, 2008 at 07:37 AM
Yakim Peled
p.1 #4 · Impressive BH-25LR and Gorillapod SLR performance
Hummmm…….
I just thought about it. Would this post be better suited in the General Gear-talk forum? Fred, if you think so, please move it.
Happy shooting,
Yakim.
May 24, 2008 at 07:44 AM
Yakim Peled
p.1 #5 · Impressive BH-25LR and Gorillapod SLR performance
Sorry but I didn't understand the question. Can you please re-phrase it?
Happy shooting,
Yakim.
May 24, 2008 at 07:46 AM
GeorgeM
p.1 #6 · Impressive BH-25LR and Gorillapod SLR performance
And your son?
Where is he?
May 24, 2008 at 07:47 AM
Jman13
p.1 #7 · Impressive BH-25LR and Gorillapod SLR performance
Happy shooting,
Yakim.
Well, the Gorillapod is supposed to be a master at holding on to things - tree limbs, railings, poles, etc...giving you a tripod where no other tripod would work...I was wondering how steady it can hold that rig when it's not using the three legs for support, but rather with the legs wrapped around something. I've seen some impressive stability from the Gorillapod in these instances, just not with that much weight.
May 24, 2008 at 08:04 AM
Yakim Peled
p.1 #8 · Impressive BH-25LR and Gorillapod SLR performance
GeorgeM wrote:
And your son?
Where is he?
Sleeping.
Happy shooting,
Yakim.
May 24, 2008 at 08:20 AM
Yakim Peled
p.1 #9 · Impressive BH-25LR and Gorillapod SLR performance
Got it.
Same performance.
Happy shooting,
Yakim.
May 24, 2008 at 08:22 AM
Jman13
p.1 #10 · Impressive BH-25LR and Gorillapod SLR performance
That's impressive! I may have to pick one of these up. Does the pod articulate enough that you could just put a QR clamp on it and adjust well, or is the head a good idea? (I have an L-bracket too, so verticals aren't a problem.)
Edited on May 24, 2008 at 09:40 AM
Yakim Peled
p.1 #11 · Impressive BH-25LR and Gorillapod SLR performance
The head a VERY good idea as it enhances its usefulness considerably. Before buying the head I tried it but found it functionally lacking. Just think about setting up a tripod on uneven ground. Possible? Yes. Difficult? You bet. And in this case you can't even change the leg length to compensate for some of the unevenness.
Happy shooting,
Yakim.
May 24, 2008 at 10:05 AM
JohnJ80
p.1 #12 · Impressive BH-25LR and Gorillapod SLR performance
i guess I'm not sure I'd call that impressive. Actually, looks kind of soft to me.
In the absence of vibration, any support works well. Be interesting to see how this would work if there was some vibration present or a breeze even slight.
I'd use this thing for holding a flash, but I'm not going to put my camera on it.
J.
May 24, 2008 at 02:10 PM
EB-1
p.1 #13 · Impressive BH-25LR and Gorillapod SLR performance
2x on the 70-200/2.8 IS is not so good.
EB
May 24, 2008 at 02:13 PM
Yakim Peled
p.1 #14 · Impressive BH-25LR and Gorillapod SLR performance
It's not about IQ. It's about support capabilities.
Happy shooting,
Yakim.
May 24, 2008 at 03:44 PM
