Andre Labonte Offline Image Upload: Off
bmannon wrote:
Thinking about getting a 17-55 however also thinking of getting three primes instead. How would the zoom compare to the following....
20mm 2.8
35mm 2.0 (or 30mm 1.4)
50mm 1.4
I know I am losing the 3mm on the wide end. I would really like the ability to zoom but want the best IQ possible. The primes would also be a little less expensive and work on a full frame body in the future, but the zoom would work on a D40 type body if I ran across one of those,,,,,,,, So back to my original question, will the 17-55 stack up IQ wise with the primes?
I think you will be surprised by the performance of the 17-55, even wide open. My copy is sharp corner to corner even at F/2.8.
I recently did a wedding with this lens and found it to be a charm. The only other lens I carried was my 70-200VR for the long shots and tight-crop portraits.
The only issues I have with this lens are: its a bit prone to flare in harsh lighting situations (i.e. indoor shots with a bright window behind) but underexposing slightly solved that issue. Sometimes its a bit hard to get the hood to line-up properly to mount it.
The lens is built like a tank and although it is big and heavy, it is very well ballanced on a D300 with a grip. Ergonomics of this lens are fantastic as is the AF performance.
As you correctly pointed out, this is a DX lens, so if you plan to go to FX sometime soon, either the primes or a 24-70 might serve you better. If you are not going to FX or the conversion to FX is a ways off, go for the 17-55.
Best of luck to you.
