tomm101 Offline Image Upload: Off
Scanner Question - Should I Buy? | |
A lot of the 2700ppi scanners had problems accentuating grain on color negative emulsions, especially high speed emulsions. The negs would print nicely but scan terribly, my old Minolta Scan Multi also has this problem. This is one of the reasons that after 4000ppi scanners were introduced almost no one sold 2700ppi units.
The 1650 Epson is an older scanner and that generation Epson's did not have the best reputation with 35mm. With the V700 they seem to have solved the problems they had with 35mm. I have had one for 2 years, scans 35mm very well, 12 slides, 24 negs at a time, each can be individually adjusted. Sharpness and film grain structure is there. This scanner equalled my Nikon LS2000 in sharpness and had better dynamic range. 12 images at a time (about 1/2 hour at 3200ppi double with digital ice) is a good amount to scan, you can get away fro the scanner but not long enough to forget about it.
Good Luck
Tom
