FM Forums | Digital Art, Smartphone & Abstract | Join Upload & Sell
Archive 2008 · How does one shoot one of these?
MichelleL
p.1 #1 · How does one shoot one of these?
I can't even find a definition for what these things are.
Any idea how you shoot for one of these?
http://hchamp.com/2008/05/08/home-away-from-home/
I'd love to learn how these are executed. Any tips/tutorials/videos would be super!!!
Thanks,
Michelle
May 14, 2008 at 01:32 PM
colinr
p.1 #2 · How does one shoot one of these?
Michelle
This is my guess - PTGui
Look at their web site http://www.ptgui.com/ and see the bits of the cathedral photos .. from this example I feel it should be possible to create an irregular montage
You can download a trial version and play with it and see if this can achieve your effect
Good Luck
Edited on May 14, 2008 at 02:11 PM
lylejk
p.1 #3 · How does one shoot one of these?
Looks like a panarama mosaic to me. I think they left the seams intentional (along with leaving the carry overs instead of cropping) for added effect which is cool. A lot of freebies exists that does this. Colin gave very good advice.
May 14, 2008 at 07:55 PM
RodBarker
p.1 #4 · How does one shoot one of these?
Very easy to do Michelle , just a serious of freehand shots from roughly the same position and then layered in Photoshop , the more shots you have to work with the more creative you could get .
Create a blank document and make it much longer than higher , bring in your shots to separate layers transform blend and arrange as you like lining up different elements to get an abstract of the room .
Rod
May 16, 2008 at 04:15 AM
Osai
p.1 #5 · How does one shoot one of these?
It's actually really EASY. All you have to do is take a series of shots from one position and use Photomerge in CS3. Photomerge will put it together for you. You don't even havve to layer them. It works best with a "normal lens. Avoid wide angles.
Edited on May 16, 2008 at 02:04 PM
MichelleL
p.1 #6 · How does one shoot one of these?
Thanks so much, everybody!! I appreciate all the help and suggestions. Can't wait to get started!!!
May 17, 2008 at 01:42 AM
