Sports Corner Rules
Sports Corner Resource
2 3 end
Archive 2008 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
General Tso
p.1 #1 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
If you are a motorcycle lover like myself, enjoy these
(Smaller sizes upon request by the nice FM members ):
Gallery:
http://ButtonJam.smugmug.com/share/BciqogQYXpBto
Edited by General Tso on May 10, 2008 at 05:34 PM GMT
Edited by General Tso on Jun 05, 2008 at 11:40 PM GMT
Edited on Jun 05, 2008 at 11:40 PM
May 10, 2008 at 05:26 PM
MagicNikon
p.1 #2 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Wow. Nice colors. Well done!
May 10, 2008 at 05:27 PM
General Tso
p.1 #3 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Thanks MagicNikon - I enjoyed your work as well. I have been passing your 16-85VR test shots around...love them all
May 10, 2008 at 05:32 PM
Homey
p.1 #4 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Nice work General.
I like your panning work.
Care to share the camera settings? Like SS and Ap. settings?
May 10, 2008 at 05:46 PM
General Tso
p.1 #5 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
No problem!
I use to be a canon shooter, until I found my new home with Nikon ;-)
Primo 300mm F2.8 VR
Tv @ [1/160 - 1/320 seconds]
ISO 200 locked
The lens is effective 450mm. I have used the 1.4x TC as well bringing it just a bit over 620mm+. Overcast clouds for the past 3 days of shooting and aperture sometimes opened up to F/4.0.
Due to the distance of the bikes and my position (of course safely behind k-line blocks), your background can still be blurred pretty smoothly even at large F-STOP apertures.
These were done with a D300, NEF format. AF tracking using 9-point continuous servo mode. Of course, 8fps has it's benefits. My keeper rate is about 70% or so.
Previous batches I've shot (of other events) - a total of 40GB were thrown away - due to the stupid AF ACTIVE MODE turned on - causing some weird double blurr when hand held. It takes some getting use to hand holding the 300mm F/2.8 VR. You need shoulder muscles and alot of patience. ;-)
A tip: I would definitely bring the following:
* 70-200mm F2.8 VR
* 300mm F2.8 VR or even the 300mm F4 is fine if you have steady hands and don't mind faster shutter speeds for motion capture
* 400mm F2.8 VR (you can hand hold for 2 minutes tops...lol) - bring a 30lb tripod + panning head if you want at least 50% keeper pictures ;-)
* 1.4x TC. I would use this sparingly. Some of the images may appear a bit soft but most likely due to the AF focusing on the D300. Most shots on a bright sunny day will make you stop down towards the F/7 - F11 range. Of course, you are free to interpret your own "style" of shooting - hence the shutter speeds are always up to you to decide. I'm good at shooting @1/160 without much blurr hand held. But even then I still need assistance with a bogen/manfrotto tripod and head.
Edited by General Tso on May 10, 2008 at 08:41 PM GMT
Edited on May 10, 2008 at 08:41 PM
May 10, 2008 at 05:54 PM
yanf.jiang
p.1 #6 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Great shooting, thanks for sharing
May 10, 2008 at 06:03 PM
General Tso
p.1 #7 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
everyone is welcome
I enjoy this forum much more so than that fxxking piece of shxt dpreview
At least we have shooters here and not gear heads who only care to clean their camera daily and minimize shutter clicks. Of course I'm not talking about you guys!
May 10, 2008 at 06:04 PM
VladiD
p.1 #8 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Fantastic shots, great description / how-to.
Thanks for sharing!
May 10, 2008 at 07:30 PM
VladiD
p.1 #9 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
When you handhold the 300mm, do you keep VR on at all times?
May 10, 2008 at 07:31 PM
General Tso
p.1 #10 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
^^ short answer: YES, I hand hold with VR ON:
Whenever you shoot high speed subjects with super tele-lens, you must make sure your shutter is fast enough to stop camera shake. However, you cannot have the shutter too fast or else you will stop motion. There is no wrong or right way - only your perspective on the subject captured, however, but there is the "typical" way which is to stop enough motion with just enough blur to create "fast movement blur".
The VR helps when you have shutter speeds under 1/400". You have to remember to wait a second for it to kick in (same as canon's) and then you have to stabilise yourself - just like how to shoot a rifle at long distance...breathing is critical too.
I don't know about others, but I find it quite hard to hand hold for long periods of time (the longest for me was about 3.5hours straight). You can almost bet hand holding a 400mm f/2.8 will get you tired instantly. It's not just hand holding the entire setup, it's also being able to hand hold AND track your subject - motorcycles move FAST - sometimes extremely fast and you almost have to anticipate their movements (which comes with trivial experience shooting more and more of it).
The trick is HIGH FPS. The camera is a tool and you can only expect so much from AUTO FOCUS. You basically try to track and pan with your bike and hope the AF gets you that one shot you are shooting for. If you can get ONE decent frame from that entire HI-FPS range, you're money.
I recommend a hefty tripod/head system. If mobility and quick action is your taste, then perhaps a monopod....or a big workout at the gym but even then, you will tire out and your shots will look terrible near end of day due to fatigue.
Happy shooting!
---The General
Edited on May 10, 2008 at 08:50 PM
May 10, 2008 at 08:49 PM
Hask
p.1 #11 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Outstanding shots, and cool lens
May 11, 2008 at 07:25 AM
Mike LaPutt
p.1 #12 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Cool bike shots. I wish a lot more folks did them. The variety helps broaden the different styles of images we all get.
May 11, 2008 at 04:05 PM
Sven Jeppesen
p.1 #13 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Great series, very crisp
May 11, 2008 at 10:12 PM
Jonathan Knight
p.1 #14 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
I'd love to look at them, but you are eating up my laptop. Pictures are way too big to look at.
Please only post 10, 800px on the long side images, PLEASE!
I didn't want to even look at your shots because it was taking too much time to load and I have a very new, clean MacBook that never has issues.....
SMALLER SIZES, PLEASE!!
May 12, 2008 at 01:13 AM
Carl Auer
Moderator
p.1 #15 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
thank you Jonathan...yes, way too many photos, especially when posting them twice. Link to larger images if you need to, but on my Mac Pro and broadband connection it took forever to load the large images....I also use my iPhone to check the site when I can and it took almost 30 minutes to load this page.... should only take a minute there....
May 12, 2008 at 02:57 AM
slomaroz
p.1 #16 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Love the shots, and the colors are amazing!
I'm getting ready to bite the bullet and get the canon 300 2.8 IS, I'm excited, I think it's a great lens canon or nikon.
I have a friend who shoots nikon for ESPN, he said the nikon 300 2.8 was an awesome lens. As you've proved with magazine quality shots!
May 12, 2008 at 03:18 AM
Jonathan Knight
p.1 #17 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Didn't even check on my iPhone....who knows how long it would have taken!
I was on a wireless University connection at full strength in the library....and it took about 5 minutes to load the page. Most posts with 10 photos will take about 15 seconds.
Edited on May 12, 2008 at 03:24 AM
May 12, 2008 at 03:23 AM
Pehpsi
p.1 #18 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Totally kick-ass! Your shots are amazing, well done. I hope to be able to produce shots like you in the not-too-distant future..
James.
May 12, 2008 at 03:28 AM
veeral
p.1 #19 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
I'm slowly finding myself getting more and more absorbed into motorsports thanks to fantastic images such as these. The color and sharpness are sensational.
Me being a Canon guy the black Nikkor lens looks so hot I guess I'm suffering from lens envy as I am waiting and waiting for my 500mm to come.
May 12, 2008 at 01:29 PM
Rags Hef
p.1 #20 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Great shots General. Thanks for the tips, they were very helpful.
Rags
May 12, 2008 at 02:48 PM
General Tso
p.1 #21 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Thanks to all for the comments
I had some free time so I posted some more frames for anyone who wants to view. They are all in the gallery here:
Part 1 Samples for Cascade TrackTime @Portland International Raceway - May 9, 2008
May 15, 2008 at 04:22 AM
Bill Gass
p.1 #22 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Man......Those are some killer shots............Nice work bud...
~Bill~
May 16, 2008 at 07:23 PM
Hockey man
p.1 #23 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
These are spectacular shots. Great colors
May 16, 2008 at 10:08 PM
PrecisionPhoto
p.1 #24 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
Excellent work, however I would have like to see the bikers just a bit less in motion and more in focus and do understand the need to convey speed and motion in the same shot.
Have any shots where you freeze everything at a much higher shutter speed to see what the lens is capable of in sharpness stopped ?
Thanks
Jun 05, 2008 at 06:17 AM
BenV
p.1 #25 · "PRIME" fun (motorcycle) - HIGH BANDWIDTH
pretty good shots
Jun 05, 2008 at 04:08 PM
2 3 end
