Archive 2008 · A depressed flag
JasonRussell
p.1 #1 · A depressed flag
I really need some opinions.
I normally use PS for touch ups b&w conversions and small adjustments. This is the first time I tried anything like this and I know its not too great. Any ideas on how I can improve or what I did wrong?
I wanted the picture to give the viewer the feeling of depression while viewing such a patriotic symbol.
Edited on Apr 07, 2008 at 02:00 PM
Apr 07, 2008 at 01:52 PM
sbeme
p.1 #2 · A depressed flag
Want to post the original?
Quick thoughts:
Vignetting idea good, but overdone.
House in the backgroud is a problem and doesnt belong. The flag against the almost empty sky and OOF branches can work for you.
Should the flag be at half mast?
Scott G
Apr 07, 2008 at 02:17 PM
JasonRussell
p.1 #3 · A depressed flag
Thanks Scott.
Here is the original.
The vignetting wasn' ...lol.t that dark when I did it at first but I actualy darkend the whole picture and that made it darker around the edges. I actually like how dark it is ...lol.
I actually wanted the house in the background. It goes with the story I posted in my blog. (There isnt an angle that I could shoot the flag without a house in the BG anyway)
I didnt just want a flag, I wanted it tied to a home, a family, and to the old American ideals. I wanted it to make the viewer remember what the American dream used to be.
And I dont think the flag should be at half mast today.
Edited on Apr 07, 2008 at 03:28 PM
Apr 07, 2008 at 03:01 PM
sbeme
p.1 #4 · A depressed flag
Jason,
Very helpful to have you clarify your intent.
Couple more thoughts, after playing with it a bit in LR.
First, why not crop out the extreme left, getting rid of the flag holder or gutter, or whatever that is at one end of the pole? Not sure what that adds, other than an anchor to a structure. You could also crop a bit from the bottom, eliminating the dark lower left object (gutter?).
Second, I wonder about desaturating the house quite a bit, and even desaturating the flag a fair bit.
Finally, I like the vignetting, but perhaps going a bit lighter?
Should be interesting to see what others think.
Scott
Apr 07, 2008 at 04:11 PM
JasonRussell
p.1 #5 · A depressed flag
Ill try that Scott, thanks.
What can I do to select just the house to desat. it?
Apr 07, 2008 at 04:39 PM
sbeme
p.1 #6 · A depressed flag
As always, with PS there are several ways. And a quick way in LR.
One method which is similar in both, is to select Color Range, click on the house, adjust the fuzziness slider to capture the house, then use an adjustment layer for saturation and reduce saturation to taste. You could also approximate the colors you want to reduce by selecting a hue/saturation layer, clicking on greens, adjust the color range sliders beneath, then adjusting saturation (and lightness). In LR, you go to HSL, use the target tool wth Saturation selected, click on the house side, and drag down.
Or, in PS, duplicate the background, in the dup layer use your selction tool of choice, add an adjustment layer or adjust image, and again work with Hue/Saturation.
Here is my quick LR version:
Edited on Apr 07, 2008 at 06:31 PM
Apr 07, 2008 at 06:30 PM
D.L. Olson
p.1 #7 · A depressed flag
WOW, sbeme, that's amazing!!!
Apr 07, 2008 at 07:04 PM
JasonRussell
p.1 #8 · A depressed flag
I kinda like that one too. Im gonna have to work on my PS skils...lol.
Thanks Scott
Apr 07, 2008 at 07:42 PM
sbeme
p.1 #9 · A depressed flag
Jason and DL,
Glad you liked it.
Jason,
Glad it worked for you. Of course, its your image, your vision that is interpreted. Again, your explanation of your intent and context is key. In addition to adjusting saturation, I did a bit of curves work to keep the image fairly dark, a bit of the vignetting, and cropping as described above.
Apr 07, 2008 at 07:49 PM
JasonRussell
p.1 #10 · A depressed flag
How does this one look? I kinda like how the colors on the flag are still bright.
Apr 07, 2008 at 07:50 PM
sbeme
p.1 #11 · A depressed flag
Jason and DL,
Glad you liked it.
Jason,
sbeme
p.1 #12 · A depressed flag
You've got some artifacts along the length of the flagpole, with a parallel area of darkening close to the base. I'd clean that up.
Apr 08, 2008 at 03:32 PM
