Vance Zachary Offline Image Upload: Off
Canon 24-105 for weddings | |
I use the 24-105/4L IS and like it mostly for the IS and its wide focal length range; for most storytelling images, it is perfect with the 5D; in very, very low light or in low light with fast action (fast dancing) or if I want less depth of field, I switch to a fast prime lens (max apoerture 1.2 or 1.8); I also have the Tamron 28-75/2.8 but, in low light, it is slow to focus
At 24mm, however, there is noticeable vignetting and wide angle distortion at the edges with the 24-105/4L IS; more than the 24-70/2.8L; so I avoid that focal length or avoid putting faces at the edges when using it
otherwise, a fantastic overall lens for weddings or travel with the 5D; some top wedding pros such as Jerry Ghionis use this lens with fabulous results; I would wholeheartedly recommend it
Good luck with your decision!
