What are the criteria?
FM Forums | Photo Critique | Join Image Upload
rashley
Image Upload: On
p.1 #1 · chevy again!
Comments welcome.
Mar 11, 2008 at 09:59 AM
Scott Stoness
Image Upload: On
p.1 #2 · chevy again!
The picture feels tight - I think you need to back up a bit or move in lots and just pick a piece of the winshield.
Framed through emblem bottom right
Framed through door frame left
tight on the right near frame
Board above seems awkardly framed through
Nice subject and exposure, I would pick a different frame and it woudl be good.
Mar 11, 2008 at 01:15 PM
tifster
Image Upload: Off
p.1 #3 · chevy again!
I love the interesting breaking pattern in the glass and the way it stands out because of the lighting. I'm distracted by the fact that I can't tell where the truck ends and where that board on top begins.
--Paul
Mar 11, 2008 at 09:53 PM
rashley
Image Upload: On
p.1 #4 · chevy again!
Hope this answers your questions. Unretouched...Straight out of the D200.
Mar 11, 2008 at 10:33 PM
sbeme
Image Upload: On
p.1 #5 · chevy again!
Rashley,
You have some interesting shots here and I would view them as part of a series. Guidelines suggest you only start one thread per day and I think grouping these images together (actually I'd suggest a max of 3) for critique and comparison would be appropriate.
I think you have a great subject. Loss of shadow detail is hurting the images and it is worth experimenting with different crops, as others have suggested. Shadow/highlight tool is your friend. I'm not sure how well pop-up flash would have helped; you might have then had to remove some reflections in the windows.
I think BW conversion or toned image is worth playing with as well. However, your color image illustrates some loss of tonal range in the conversion above. You might try experimenting with different color filters with BW conversion to preserve a broader tonal range across the hood of the car, for example. Or a bit of curves work, masked over the windows, to provide increased contrast between the rusts and greens. I'm not at home to see how close those points might fall, so I'm not as confident in that approach as the filters. What is your technique for BW conversion? Which program?
Scott G
Mar 12, 2008 at 08:10 PM
rashley
Image Upload: On
p.1 #6 · chevy again!
Thanks for the input. I am glad I asked.
Mar 13, 2008 at 12:06 AM
Lost password?
