Ben Horne Offline Dedicated FM Upload & Sell: On
jamesf99 wrote:
Ben Horne wrote:
I picked up a 45mm TS-E lens here on FM for use on a trip. I LOVE this lens. Now that I am use to the lens movements, I find it difficult to use "regular" lenses now. I have learned several things about this lens that I thought I should pass on. First of all, you really NEED the angle finder C in order to tell if you have the lens properly setup. Otherwise, it is difficult to tell in the viewfinder if you have the lens tilted and focused properly. Here is a test shot yesterday with the 45mm TS-E tripod mounted, tilted almost to the max. I believe the shot was taken at f/8. With a normal lens, you'd get only a small percentage of the shot in focus at f/8.
I was well aware that Chromatic Aberration would be an issue with this lens. It's quite a bit more than I thought, but it also isn't that difficult to get rid of. You can NOT use the CA fix in Adobe Camera Raw since this is a different style of CA. On a normal lens, you will find that the red channel is slightly larger yet centered. As a result, the further you get from the center of the lens, the stronger the CA will be. Photoshop can essentially shrink the red channel, yet keep the center aligned, and you will have proper alignment.
With a TS-E lens, your image circle is huge, and depending on how you have the lens tilted/shifted, you will see only a portion of the edge of the image circle. This means that the CA is not radial, and centered in the middle of the photo. With a little bit of experimentation, I found that if you shrink the red channel to 99.92% of it's original size (on the 1DsmkII), you will now have a red channel that is the same size as the blue and green channels. Then you just have to align it. In the shot with the rocks on the beach, I set the height to 99.92%, left the width at 100% (uncheck the constrain proportions box) since there were not any red channel alignment issues on the other axis. Here is a 100% crop before and after the red channel shrinkage.
I also found that 99.92% worked for correct CA on this lens that results from shifting to the max..............
OK, someone has to ask the dumb questions so it's my turn today.
I'm not sure what you mean by shrinking the red channel so can you explain that in more detail? I've used the 24,45,90 for years now and have never done that so if I'm missing something that obviously appears to improve things, I'd like to understand it. I'm also quite familiar with PS, but as we all know, there are 100 ways to do the same thing...
thanks
Load a photo from one of these lenses that has some severe CA. Next, look at the channels pallet. Click the blue channel, then the green channel, then the red channel. You'll see that the blue and green channels are properly aligned, but the red channel is off. The light in the red spectrum does not focus properly, causing the info on the red channel to be slightly larger. This is why you see the color fringing --- it is because not all the colors are focusing on the same plane. By shrinking the red channel, now the color channels are all the same size. When aligned properly, the vast majority of the CA will be fixed.
