Archive 2008 · The Demon Within me.
Ericson C.
p.1 #1 · The Demon Within me.
http://farm3.static.flickr.com/2387/2192310030_4f5cbf3e88_o.jpg
Jan 14, 2008 at 05:38 PM
Jammy Straub
p.1 #2 · The Demon Within me.
Interesting image, is that a post photoshop filter you've got going on over your skin?
I'd almost like to see the image with the pattern on your skin projected from the light source. A type of gobo if you will. That could be tricky, but fun, to set up.
It feels very angry, you've got that coming across. I do like the use of the shadow projected on the rear wall.
Jan 15, 2008 at 12:29 AM
Ericson C.
p.1 #3 · The Demon Within me.
Yes, It was a photoshop filter. If I had the time to do this to my actual skin I'd have a better shot I think..haha. I'll try and see if I can get a pattern in the shadow. I already tried to apply some horns but that did not work out too well..haha.
If only I could say.. ,"That took hours of glitter and glue..and yes, that is my third nipple." That would be funny.
Jan 15, 2008 at 01:39 AM
RobWNY
p.1 #4 · The Demon Within me.
For me the use of the Photoshop texture alone takes away form the image. I'm not saying a texture wouldn't work with the image, but it needs more crafting so not to appear flat against skin that has depth. I think if you created a PS displacement map based on your skin highlights & shadows, and then applied a texture using the d-map to it, the results would be much better.
Jan 15, 2008 at 03:18 PM
Ericson C.
p.1 #5 · The Demon Within me.
I wish I knew how to do that.. :\
Jan 15, 2008 at 04:23 PM
RobWNY
p.1 #6 · The Demon Within me.
Google "Photoshop Displacement map" my friend.
Heck, you could even pull it of by hand tweaking it with the Liquify Filter if that route suits you better.
Edited on Jan 15, 2008 at 05:15 PM
Jan 15, 2008 at 05:12 PM
Ericson C.
p.1 #7 · The Demon Within me.
I will check it out. Thanks Rob.
Jan 15, 2008 at 06:03 PM
Ericson C.
p.1 #8 · The Demon Within me.
Wow. Awesome stuff. I'm going to try this.
Jan 16, 2008 at 03:02 AM
Matt Battaglia
p.1 #9 · The Demon Within me.
As a general rule of thumb, if people spot a filter right away it usually cheapens the image and gives it a very amateurish look.
Either axe the filter and let the shot speak for itself, or really spend some time to merge the effect with the image.
Try making a duplicate layer of yourself without the filter, and add a layer mask. Then go in and paint out areas of the "scales" to make it seem a little more natural. Maybe they only show up in the dark shadowed areas. Also you have very strong directional lighting coming from the bottom, but to me it appears that the emboss effect you used has the highlight coming from the top. Another thing you should do is adjust the color of the effect. Use purples and blues for the darker area and blend them into skin tones in the highlight areas.
Jan 16, 2008 at 09:51 PM
BenV
p.1 #10 · The Demon Within me.
Good ol' photoshop to define muscles :-)
Jan 16, 2008 at 10:27 PM
Ericson C.
p.1 #11 · The Demon Within me.
Nope. no muscle defining here. What you see is what you get.
Jan 17, 2008 at 01:01 AM
Chefdaniel
p.1 #12 · The Demon Within me.
IIIIIIIIIIII AMMMMMMMMMMMMMMM IRON MAN!
That guy looks pissed off. Scary shit!
Edited on Jan 22, 2008 at 08:31 PM
Jan 22, 2008 at 08:30 PM
