Archive 2008 · Canon Pro9000 page position help
chipiii
p.1 #1 · Canon Pro9000 page position help
Hi to all,
I am sure this is a simple question, but I don't seem to be able to find the answer easily in the online manual or elswhere. I am the prowd owner of a new 9000 ans so far am thrilled at the results. I am starting to lear all the profile / paper /color issues but here is the issue.
I am trying to print an A3 (13 x 19) sheet as a test and so far cannot get the photo to center on the page. I am using Photoshop CS and the EasyPrint Pro plug in. On the monitor everything looks centered but when printed the print area is off center by at least a 1.5 in or so. I have tried the options in EP Pro to center on page etc. with no changes. ANy ideas or do you need moreinfo?
Thanks,
Chip
Jan 11, 2008 at 11:32 AM
SoundHound
p.1 #2 · Canon Pro9000 page position help
Why not check the box in the PS "Print" pop-up box "scale to fix media" then go to Page Setup select you printer in the box Format For then select "Borderless" 13 x 19" in "Paper Size." Finally check to verify that in the Print window that your selected "Printer" in the drop down box is the Pro9000.
If that doesn't work call Canon support @ 800 385-2155 and, at the least, they will talke you thru printing with their own software.
Jan 11, 2008 at 12:38 PM
chipiii
p.1 #3 · Canon Pro9000 page position help
Thanks, I will certainly try that. I meant to say in my post that the "print preview" on the monitor shows that the image is centered. Not just centered on the monitor.
Jan 11, 2008 at 04:10 PM
