Archive 2008 · Vista and CS3
DIS Ottawa
p.1 #1 · Vista and CS3
I'm thinking of changing from XP to Vista when SP1 is issued. I currently use PS CS3 and print with an Epson Pro 3800.
My PC has two GB RAM and was built for me about a year ago and, according to the upgrade test from Microsoft, will run Vista fine.
Does anyone have experience with this combination? Are there any known issues with Vista working well with CS3 and the Epson drivers? Would adding two more GBs of RAM be wise?
Thanks for the help!
DIS
Edited by DIS Ottawa on Jan 10, 2008 at 02:13 AM GMT (Reason: Typo)
Edited on Jan 09, 2008 at 01:13 PM
Jan 09, 2008 at 10:59 AM
cdodson
p.1 #2 · Vista and CS3
Hi DIS,
I run Vista and CS3 with 2GB RAM and have no trouble. If you are able to add more RAM definitely go for it. You will never say to yourself "gosh, I wish I had less RAM". I can't help you in the printer arena though.
Hope this helps.
Chris
Jan 09, 2008 at 11:57 AM
DIS Ottawa
p.1 #3 · Vista and CS3
Thanks Chris, it does indeed help. And you're quite right, I've never said that!
Jan 09, 2008 at 01:12 PM
Sarsfield
p.1 #4 · Vista and CS3
I would need to understand WHY you would want to upgrade to Vista to accurately answer your question. I have two laptops running Vista, two running XP and a desktop running XP (all networked in my home). I have gone through all the early problems with Vista and CS3. I have done a million updates, upgrades, increased ram and other gyrations and I have one thing to say:
Unless you have to, don't do it.
Vista offers NOTHING to a serious computer/CS3 user. And, unless you have at least a core duo or core 2 duo processor (or Athlon equivalent) you will actually slow down your workflow. I can guarantee it. Oh, and another thing - have at least 24 hours for the upgrade to Vista and plan on reformatting everything prior to it and plan on reinstalling all your hardware/software with new drivers and upgrades.
If you are a masochist or a chronic tinkerer, have fun. If not, stick with XP or upgrade to XP pro if you want 64 bit.
Jan 09, 2008 at 03:37 PM
DIS Ottawa
p.1 #5 · Vista and CS3
I don't have to move to Vista (note I didn't say upgrade) but have been considering it as I have Vista on a laptop and it works very well. Eventually, PC users will have to migrate to the new system and I was thinking that once Service Pack 1 comes out, this might be a good time.
I have a Core 2 Duo 6400 or 6600 processor (can't remember which offhand) and 2gb RAM so should be able to handle Vista but my concern was aound just the things you have mentioned, driver updates, software compatibility, etc.
Your quite unequivocal advice, then, is to stay far, far away from Vista?
DIS
Jan 09, 2008 at 04:20 PM
Sarsfield
p.1 #6 · Vista and CS3
Yes, that would be my advice. Don't count on MS discontinuing support for XP anytime soon. There would be a HUGE backlash in the IT community if they did and their current plan calls for full support through 4/09 with extended support for another 5 years after this. See this:
http://www.msnbc.msn.com/id/16805062/
Jan 09, 2008 at 04:31 PM
DIS Ottawa
p.1 #7 · Vista and CS3
Thanks for the advice and link.
Jan 09, 2008 at 04:36 PM
Matt B.
p.1 #8 · Vista and CS3
Vista? Isn't it full of bugs? That's what I've heard.
Jan 09, 2008 at 05:11 PM
timgangloff
p.1 #9 · Vista and CS3
A lot of people bash Vista. I am not sure why. A lot of these same people bashed 98, Me and XP when they came out too. (Now, Millenium Edition really did stink, but that's another story). I installed Vista Ultimate home about a year ago when it first came out. By day, I was a computer geek and wanted to try the newest and greatest. To hedge my bet, I made my dual core system a dual boot, keeping XP just in case. I use CS3 and a host of other programs photo related, all with no problems. Vista is as stable for me as XP ever was. I have not had to boot into XP in quite some time.
I have an Epson 3800 and a R200. The R200 is a bit problematic as the Epson software for that printer is not fully functional in Vista, or at least it wasn't a few months ago when I looked last. The ink management system does not work in Vista for that printer. The 3800 works wonderfully in Vista. Epson apparently does not want to take the time to make the R200 work, so occasionally I'll boot into XP to see what my ink levels are and replace any low tanks. I don't use that printer much, so its not a big deal. The only other software that Vista struggles with is Dr. Divx, a dvd to divx conversion program. Other than those two, I am not aware of any software that does not work with Vista that would be used by most photographers, including Nero, Photodex, Photoshop, DPP, Lightroom, Capture One, Qimage, Faststone Image Viewer, and Lumapix to name a few I use regularly.
There is a lot of hype and a few vocal disgrunteled Vista users out there, but every time I've asked what issues specifically they are having with Vista, I don't get any specific answers. Look, I am no MS fanboy, but I'll tell you like I see it. Vista works fine and there are a few nuances that take some time to learn and some older hardware may not work completely. For this last reason, if you are a large corporation in a production environment and all of your hardware works well with XP, then do not go to Vista. However, if you like to play with the newest stuff, then go for it.
I actually think it takes less time to install Vista than XP as Vista has so many more drivers built in that you will be amazed at how much of your hardware will work without having to do any more work installing drivers. As with any new install, I recommend a clean install vs. an upgrade (you can still use an upgrade disk, but just do a clean install).
Jan 09, 2008 at 06:08 PM
DIS Ottawa
p.1 #10 · Vista and CS3
Good one Matt! Fun, eh?
DIS Ottawa
p.1 #11 · Vista and CS3
Thanks Tim, that provides a strong and balancing view from the other side.
One does hear some complaints about Vista, and they are no doubt valid. I suspect, however, that as my computer is less than a year old I should have few if any problems from a hardware perspective. My primary program usage is with Photoshop CS3, the Nik Color Efex Pro 2.0, Epson 3800 and Office 2007 Home and Student and I suspect I won't have much trouble there either.
Jan 09, 2008 at 06:26 PM
