Archive 2008 · Recommend a pen tablet?
Reneemarie
p.1 #1 · Recommend a pen tablet?
Anyone use one? I think I would really like one because of my love for drawing. I was hoping someone could recommend one around the $200 range.
Thanks,
Renee
Jan 08, 2008 at 07:37 PM
DIS Ottawa
p.1 #2 · Recommend a pen tablet?
Go here:
http://www.wacom.com/index.html
Wacom makes the best tablets and pens and has a pro line and a "fun" line. They also have a little program that helps you to pick a model.
I bought a big one and love it, much better than a mouse, but feel I could do equallly well with a smaller one.
Jan 08, 2008 at 07:44 PM
tell
p.1 #3 · Recommend a pen tablet?
I've had a Wacom for almost two years now. I try and force myself to use it but I'm so used to the mouse that I always end up ditching the tablet.
Jan 08, 2008 at 08:11 PM
Reneemarie
p.1 #4 · Recommend a pen tablet?
thanks DIS. I was considering the 4x6 INTUOS.....
ah thats funny tell...
Ironically, I do 100% of my post work on a HP dv9000 laptop, with the little tiny pad thing and my finger. I haven't used a mouse in about a year. lol
Jan 08, 2008 at 08:23 PM
Joe Piotrowski
p.1 #5 · Recommend a pen tablet?
I have the 4x6 Intuos3 from WACOM and wouldn't be without it. I really don't see how anyone can use PS without it. It is plenty big. I also think you can get a good deal on CS3 if you buy the tablet.
I can't see doing any masking with the mouse.
No need if you only use camera raw type functions though.
Jan 08, 2008 at 10:09 PM
Peano
p.1 #6 · Recommend a pen tablet?
I use an Intuos3 4x5 (I think the 4x6 replaces that now). Wouldn't be without it. A word about size: If you're schooled in traditional drawing technique -- i.e., moving the arm and shoulder when you draw -- then you might want a larger size.
If you draw as you write -- controlling the pencil with your fingers -- the small tablet will do fine. In fact, I mapped my 4x5 so that the active area is about half of what's available..
Jan 08, 2008 at 10:42 PM
Alistair Watson
p.1 #7 · Recommend a pen tablet?
I use a Wacom Intuous3 A4 tablet and it is great but takes up quite a bit of desk space. Next time I will buy the smaller A5 tablet since it is smaller and will still do everything I need.
Jan 09, 2008 at 05:34 AM
zappahead
p.1 #8 · Recommend a pen tablet?
check this out: https://www.digitalgraphicsresources.com/index.asp?PageAction=VIEWPROD&ProdID=2040&gclid=CMyUr5u06ZACFQ66PAodLXTXYQ
4x5 for 139.00 Free S & H
Jan 09, 2008 at 09:54 AM
claudermilk
p.1 #9 · Recommend a pen tablet?
When working on editing images, I wouldn't be without mine now. The small size (4x6) works just fine for general photo editing work.
Jan 09, 2008 at 11:51 AM
Sarsfield
p.1 #10 · Recommend a pen tablet?
Make note-this is a refurb, not new. You can get a brand new 4X6 for about $50 more.
Jan 09, 2008 at 04:21 PM
Andrew W
p.1 #11 · Recommend a pen tablet?
To many people, myself included, Wacom tablets are the only way to go. They are expensive, but their compatibility is second to none. I have an Intuos 4x6 tablet, and its great. Wacom just released a less expensive entry level tablet called the Bamboo which should be fine for most people.
Something to remember- when you are considering a tablet, make sure it has the same aspect ratio as your screen(or close). If you are using a 4:3 monitor, get a 4x5 tablet. If you are using a 16:10 monitor, get a 4x6 tablet, etc etc.If you don't get a tablet that corresponds with your monitor, then the accuracy will be off.
Jan 09, 2008 at 04:31 PM
RDKirk
p.1 #12 · Recommend a pen tablet?
A tablet makes a world of difference when creating masks, dodging and burning, and making accurate movements in Photoshop.
A 4x5 Graphire or Bamboo gets you to the point of diminishing returns instantly. They give you 95 percent of what you'd get with a larger tablet or an Intuos...unless intend to get into serious graphic work.
If you want to paint, Intuous gives you finer touch control, and a larger tablet enables you to "paint from the shoulder." But if you intend to make pencil-like movements, the low-end Wacom tablets take you where you want to go.
Jan 09, 2008 at 10:41 PM
