Archive 2008 · Change LR defaults?
Brooke Clyde
p.1 #1 · Change LR defaults?
I'm not seeing this in the book. I'd like to change the default settings that LR opens with (currently 25/1/25/0). Do I have to set up a user pre-set? I'd rather just have it open to my settings.
TIA
Jan 04, 2008 at 01:56 PM
egd5
p.1 #2 · Change LR defaults?
I'm going from memory here, but.... yes you make a user preset. Then in the import dialog box you choose that preset and then everytime you import a new batch that preset will be applied-unless you change it again. It's easy, even I figured it out.:-)
Jan 04, 2008 at 08:51 PM
Brooke Clyde
p.1 #3 · Change LR defaults?
I've done the pre-set thing, applying the setting as the file is imported. Just seems that it would be easier to change the defaults ...
Jan 05, 2008 at 10:35 PM
Nathan Padgett
p.1 #4 · Change LR defaults?
Under the Develop module, go to Develop, then set default settings.
Jan 07, 2008 at 11:44 AM
