Archive 2008 · Bridge problem - need help
tomhh
p.1 #1 · Bridge problem - need help
I have been running CS3 for a long time now, so I got the bright idea to un-install CS2. Now I cannot open anything except CR2 into CS3 from bridge.
The only option listed is to open into another program (Roxio...) and that is listed as default. No other option available. Any ideas appreciated
I did save CS2 preferences as suggested by the un-install.
Jan 01, 2008 at 10:34 PM
Duncan Staples
p.1 #2 · Bridge problem - need help
Try installing latest version of ACR and see if that re-indexes your CS3 Bridge to open other file types.
Jan 01, 2008 at 11:31 PM
DIS Ottawa
p.1 #3 · Bridge problem - need help
I had similar problems and had to clear the cache and do a couple of other things. Use Help in PS or Bridge and it should tell you how to do this.
Jan 02, 2008 at 01:54 PM
James_N
p.1 #4 · Bridge problem - need help
Seems like your File Associations got messed up. Open Bridge and go to Edit > Preferences > File Type Associations, the press the Reset to Default Associations button and restart the application.
If that doesn't work, go through the same routine again but don't click on the Reset to Default button. Instead, click on the downward pointing arrow on the right side of each file type line and select the application you want to open each file type.
Jan 02, 2008 at 04:58 PM
tomhh
p.1 #5 · Bridge problem - need help
Tyanx for the help. I had to go to my computer/C:/folder options and reset the file associations. Probably had the same effect as what James_N suggested.
Jan 05, 2008 at 12:14 AM
