Archive 2007 · Where is EXIF Data?
stklaw
p.1 #1 · Where is EXIF Data?
Just got a new 1DS and I'd like to see all the EXIF data in PS. I have CS3 and Bridge. Can someone tell me where I can find all the EXIF data? Will it tell me the Picture Style?
Brad
Dec 25, 2007 at 09:27 PM
vetkrazy
p.1 #2 · Where is EXIF Data?
All the data should be displayed in Bridge when you open the photo. It is called metadata. Edit/Preferences will allow to set the fields you want to see.
Dec 25, 2007 at 10:47 PM
ohenry
p.1 #3 · Where is EXIF Data?
Picture style is a Canon proprietary item. You can see that if you use Canon's DPP or other software that came with your camera
In CS3, select File>File Info and a window will pop up giving you the EXIF data
In Bridge, it depends on how you set it up, but there should be a window with a folder that says Metadata. Or you can right click on the picture and select File Info.
Dec 25, 2007 at 10:48 PM
OutsideShooter
p.1 #4 · Where is EXIF Data?
Look under Advanced then EXIF Properties within PS by right clicking on image border then choosing File Info. I do not see Picture Style, but I do see all of the Properties within the capture mode. So I think the answer is no, but at least you'll know what happened in all modes.
Dec 26, 2007 at 09:15 PM
stklaw
p.1 #5 · Where is EXIF Data?
Thanks all. I found it with your help.
Brad
Dec 27, 2007 at 08:44 PM
