runamuck Online Image Upload: Off
The way the head is set up, the handle/trigger would be at right angles to the lens length. Asssuming (not always good) that you are right handed and operating the trigger with your right hand, this is the most ergonomic method.
I use the equivalent of the 3265 ballhead, which is a vertical version of the 322. I have become quite adept to working the lever with my left hand and steadying/aiming the camera with my right. The 322 is set up bass-ackward from the way I work. If they made a left-hand model, I would get it.
With the vertical grip, I work movements with both hands, while my right hand remains on the camera handgrip and shutter. The 322 forces you to do everything with one hand.
I do use the 3265 witha Sigma 70-200 f2.8. It is about all the head can handle. The weight plus the length of the pistol grip makes it like a big lever trying to force the ball. Using the tripod mount on the lens reduces this somewhat, but it still gets heavy even a little off true vertical. Think foot-pounds of torque here.
Always use the tripod foot on the lens. At some point, the length and weight of the lens act like a big lever, and try to pull the lens mount out of the camera body. I've seen cases where the lens has succeeded. To get an idea of the forces involved, try holding the lens just by the camera mount. At some point, hanging the camera off the back of the lens is far less stressful than trying to anchor the camera and let the lens hang free. Again, think foot-pounds of torque. If the lens comes with a tripod mount, use it. Replacing a ripped-out lens mount is a very expensive repair.
