dan9 Offline Upload & Sell: Off
p.1 #20 · Why isn't very low ISO available? | |
Damian R wrote:
Hope some technical expert can satisfy my curiosity here. Thanks.
Put simply, when you change the "ISO" on your camera, you are doing nothing to the sensor! Changing the "ISO" is equivalent to changing the volume on your stereo. However, try to turn down the volume below the lowest point on the knob!
When you change the ISO on the 5D to 50, what ends up happening inside the camera electronics is that the digital value (after the analogue to digital conversion) gets divided by 2 (to make up for overexposing the image by a factor of 2 - yes "ISO 50" is really "ISO 100"). If you want an "ISO 25" then one would divide by 4, etc.
As was mentioned earlier, the problem with this approach is that once the sensor diode saturates you get no further information, so you end up with lots of blown (i.e., RGB values = 255) pixels. In other words, less headroom, and thus less DR.
