cogitech Offline Dedicated FM Upload & Sell: On
p.1 #21 · best wide angle lenses!!! | |
AGeoJO wrote:
cogitech wrote:
Some of the best landscape photos I took were with a CZ21 on a RebelXT. Sure, it is only a 33.6mm equivalent FOV but that is still considered "true" wide-angle, IMO. Is it super-wide or ultra-wide? No.
On FF or crop, there is simply no better WA than a CZ21 as far as image quality goes. Imagine the quality of the 85L at f8. The CZ21 can do that at f5.6. Truly remarkable. There is no Canon wide that is even in the same league except the 35L, which is decidedly *not* wide on a crop camera.
Paul,
I have been using one for almost two years and yes, I am fully aware of the optical quality of this lens. But to fully exploit this lens, you will have to use a FF camera as this lens gives performance all the way to the corners, which will get cropped on, well, a crop body.... Plus, the difference of 12mm in the wide angle range is huge but almost negligible in the tele range.
I tested my CZ21 on both a 5D and 1DsMkII and, yes, it is definately in its element on FF. Amazing, actually!!
And yes, the difference of 12mm on the wide end is huge, but does this make using the CZ21 on a crop camera somehow "less good" if a 33.6mm FOV is sufficient for the photographer's needs? It proved to be very useful to me, like I said. In fact, my widest lens is still a 21mm (for my crop bodies) and it covers my wide-angle needs quite well. Maybe the OP would find the same thing. If not, then the options are what Lasse and I mentioned and none of them will produce results even close to the CZ21. The only way to avoid sacrificing width or quality would be to stick the CZ21 (or Leica 19, or Nikon 17-35, or Zuiko 21/2 or Zuiko 21/3.5) on a 5D (or 1Ds or 1DsMkII) like I plan to do eventually.
Which reminds me, if the OP is OK with losing AF, then the best choice for both crop and FF (to get some more width on the crop and maintain excellent FF quality) would be the Nikon 17-35.
