relms  Offline Image Upload: On
I said that it was simple, so here it is. I found a piece of 1" Styrofoam at a construction site, and pinned some black paper to the front of it, then stuck the arrow through the Styrofoam from the back. After that I placed a piece of shrink wrap over the arrow and arranged it into a loose circular pattern around the arrow. The apple was cut into asymmetrical pieces and arranged to give the appearance of having exploded.
I set the camera on a tripod and mounted a 500D to the front of the 85 f/1.2, and with everything set manually, I exposed the image for 1/4 second at f/14 in order to give depth to the shaft of the arrow.
From there it was on to Photoshop for some exposure adjustments and radial blurring. First I selected the arrow, then inverted the selection so that everything except the arrow was selected before applying the radial blur. The blurred shrink wrap gives the appearance of a liquid splash resulting from the "explosion". Finally, I did a bit of cropping and flipped the image 180 degrees.
That's it. Not much trickery involved, and very little manipulation if you discount the radial blur.
Thanks, everyone, for your comments.
Robert
Edited on Sep 01, 2006 at 01:55 AM
