Archive 2005 · D2h Body Rubber
lxdesign
p.1 #1 · D2h Body Rubber
So... replaced the rubber on the CF door by purchasing the new part, and doing it myself ... but now the body rubber is coming loose... and it was kinda loose when I got it - but now its to the point where its kinda annoying, so got to get it replaced.
Does anyone know how much Nikon charges for this sort of thing?
thanks,
LX
Nov 03, 2005 at 08:37 PM
ajacobs2
p.1 #2 · D2h Body Rubber
125-150 or try yourself I have the tape they use.
Nov 03, 2005 at 09:02 PM
lxdesign
p.1 #3 · D2h Body Rubber
found out that if you order the part - it comes with a sticky removeable backing which you can do it yourself - the girl I talked to said I could do it myself If I was comfortable doing that - I think I will try it - now just have to figure out which solvent to use to remove the old glue.
lx
Nov 04, 2005 at 03:31 AM
Mars
p.1 #4 · D2h Body Rubber
lx
Few years ago, I brought my D1 to Nikon and the service personel replaced the rubber part in the CF door free....
may be you should bring your camera in the service center and have it check for the price. May be you will have a surprise, like me.
Nov 04, 2005 at 03:32 PM
johnnymg
p.1 #5 · D2h Body Rubber
thanks,
Use some 'thin' Eastman 910. Hobby shops or HD has it. That's what I did when the rubber starting coming off my D2H.
JohnG
LX
Nov 04, 2005 at 03:47 PM
lxdesign
p.1 #6 · D2h Body Rubber
ya, but its warped to the point of needing to be replaced - the rubber is stretched from being loose.
Anyhow - I will check to see how much it will cost at the service dept - cause I would rather get them to do it than I - the part is cheap.
Nov 05, 2005 at 12:28 AM
genghis45
Account Locked
p.1 #7 · D2h Body Rubber
Use epoxy---it'll stay 4-ever.
Scott
Nov 05, 2005 at 12:33 AM
erikff
p.1 #8 · D2h Body Rubber
take it to n ikon and let them do it...
Nov 05, 2005 at 02:17 PM
fastoys2nv
Account Locked
p.1 #9 · D2h Body Rubber
My D1 CF door rubber was loose so I called Nikon Canada. $5.00 CND for the rubber and the girl said she would through in the sticky tape also. But being cheap and owning an automotive shop. I trimed the edges as it had streched a little and used 3M moulding 2 sided tape to reattach it. Replacing the rubber is so easy. pull off the old rubber carefuly, clean the old glue off, wipe it down, let dry, peal and stick the new tape and the lay the rubber down pressing it into the corners and smooth it down for a good contact with the tape. done
Nov 05, 2005 at 02:32 PM
lxdesign
p.1 #10 · D2h Body Rubber
Yes, the CF Door is easy to fix - I DID IT MYSELF - but this is the body rubber, not the CF door - which is major - and I am planning to go to Nikon and have them do it... the part is really cheap - only like $33 CDN - but I would rather have the experts who do it all the time do it for me.
Nov 05, 2005 at 03:56 PM
jbregar
p.1 #11 · D2h Body Rubber
I sent my D2h into the shop to have the meter replaced and they threw new rubber on the grip for free.
Nov 05, 2005 at 07:48 PM
lxdesign
p.1 #12 · D2h Body Rubber
yes, that's what I hear they do - the girl from Nikon Canada part dept. told me that they do rubber replacement all the time.
Nov 05, 2005 at 11:41 PM
andylaiphoto
p.1 #13 · D2h Body Rubber
I re-applied my D2X door rubber with just some crazy glue and patience. It's perfectly fine now and cost me $2
Nov 06, 2005 at 03:32 AM
lxdesign
p.1 #14 · D2h Body Rubber
Andy - please read the message - its the BODY RUBBER - not the compact flash door. I already did the compact flash door - Nikon parts sell you the whole thing for $6, and 2 screws later its done.
We are talking about the Grip rubber which is glued right around the front of the camera with the red tab at the front. Its a major piece of rubber.
Nov 06, 2005 at 04:57 PM
fastoys2nv
Account Locked
p.1 #15 · D2h Body Rubber
I had a look at my D1 and if its the same basic rubber on the D2 it should not be a problem. The rubber deforms and streches with use and the fit becomes poor. The two sided moulding tape by 3M or the stuff Nikon supplies is probably the best. I would not try glue or expoy as bonding soft rubber to metal is not as easy as it looks and there are stresses at work with the handling of the camera body.. John K
Nov 06, 2005 at 07:10 PM
andylaiphoto
p.1 #16 · D2h Body Rubber
Same thing applies to the body....I did the same thing to a F100.
Nov 06, 2005 at 07:15 PM
genghis45
Account Locked
p.1 #17 · D2h Body Rubber
I agree with Andy. I don't view glueing body rubber back on as rocket science.
Scott
Nov 06, 2005 at 11:24 PM
Jon Blacker
p.1 #18 · D2h Body Rubber
While using epoxy or Crazy Glue might sound like a pretty good idea, there are reasons that the camera manufacturers use what they do; It's so they can take it off. If your camera requires a repair that necessitates the removal of the body rubber and you've re-glued it with epoxy....good luck with that.
Body rubber is also typically replaced with new when cameras go in for major repairs (ie; meter replacement) because in the course of it's removal to facilitate the repair the rubber gets too misshapen and streched to be put back on.
Nov 07, 2005 at 01:55 AM
genghis45
Account Locked
p.1 #19 · D2h Body Rubber
Are you saying that there are hidden screws under the rubber on body panels? Do you know this to be the case?
Scott
Nov 07, 2005 at 09:24 AM
Jon Blacker
p.1 #20 · D2h Body Rubber
Yes, there are several screws under the rubber panels.
Nov 07, 2005 at 06:40 PM
