KABeach Online Image Upload: Off
lxdesign wrote:
I have a Rollei which doesn't have a built in meter - and I have used my D100 and D2h to get meter readings. And I was successful in both cases. If you can read german - there is also a guide posted on the back of the camera.
I haven't read the back of my Rollei in a while (and I don't have it with me) but IIRC, I think that is just the good 'ole "Sunny 16" Rule...
My first 35mm camera was a Yashica range finder without a meter, and I got reasonably good a guessing the proper exposure...
The sunny 16 rule says that on a bright sunny day, your exposure should be f/16 and shutter speed 1/ASA... in other words, using Tri-X (asa 400), f/16, 1/400 (or rounded off the the nearest speed)...
Then, you would make allowances based on other conditions: Slightly overcast - open 1 stop, Overcast - 2 stops, Deeply overcast - 3 stops.
Cheers,
Ken
Edited on Oct 25, 2005 at 08:40 PM
