brandofamily Offline Image Upload: Off
p.1 #5 · D70 and shooing dancers | |
OK. I set camera at f/2.8 when using the 70-200mm and/or f/1.8 when using my 50mm (Aperature Priority Mode). That's mainly due to the theatrical lighting and zero tolerance on flash. Even back stage I use available like, I like the mood better.
I also set the Exp. Comp. to -.7. I do this so I can sopt meter as usual and not blow out the faces due to the spot lights. Others may disagree, but it works well for me.
If there is enough light and I can use the kit lens, for wider shots, I still use aperature priority mode and set the aperature to lowest possible number. The camera will of course adjust if it needs to.
I usually need ISO 1600 w/o flash, but have been toying w/ the idea of using Auto ISO and setting the min. shutter speed to 1/125 or a bit faster, to stop the motion.
Here's something else I just read in a D70 review. It has been reported, and is true, that under low light and Auto White Balance the images all take on a yellow hue. I have found the setting the WB in NC afer the fact has worked OK. It will range from 3000K to 3600K for a good looking image. A poster here awhile back, who works in the stage lighting industry, told me that most high school type stage lighting is in the 3200K range. That's my starting point the next time I shoot this type of event.
I'm out of ideas at this point. If you have anything else I can help w/ let me know. Hope this helps.
Edited on Aug 18, 2005 at 05:20 PM
