bka20d Offline Image Upload: On
thejaybird wrote:
Thanks guys... I thought about a cable but I'm worried about getting tangled up in it, having it swing in front of the lens and so forth. This will mainly be for family candids and that sort of thing, where I find myself lying on the ground a lot and sometimes contorting myself in strange ways to get a good angle. OK, maybe I just want an excuse to buy some pocketwizards...
the canon off shoe cord is pretty compact as it is coiled and stretches to about arms lenght. you loose ttl capability under the scenario you are describing with a vivitar unit. unless you use a flash meter, you are probably going to end up with less than optimally exposed pictures. you would be much better off with the $50 canon cord with a canon flash than spending $300 plus for pocket wizards to use with one non-dedicated hot shoe flash.
actually, the more i thought about this, the more ridiculous the idea does indeed seem. firstly because you have to have the transmitter sitting in your hotshoe, and then because you have to have a receiver plugged into the vivitar unit. what you will end up holding in your hand is not only the flash unit but the receiver.......you really should rethink this...
respectfully
