I tried to build a test circuit based on the Book "AVR Programming". It is very simple and shown here:
The circuit itself is working and the upload of my code as well:
#include <avr/io.h> /* Defines pins, ports, etc */
#define F_CPU 1000000UL
#include <util/delay.h> /* Functions to waste time */
int main(void) {
DDRB |= 0b00000001;
while (1) {
PORTB = 0b00000001;
_delay_ms(1000);
PORTB = 0b00000000;
_delay_ms(1000);
return 0;
but the ATMEGA328p([url]http://www.kynix.com/Detail/551814/ATMEGA328P.html[/url]) LED is not blinking. The LED in the lower right is lighting up so the circuit seems fine. There are no error messages in ATMEL Studio and the circuit setup seems fine to me. The hex file flashes correctly onto the chip. I even changed the LED and the ATMEL chip to a new one and still the same result. I am running out of debugging ideas.
The fuse settings and avrdude output:
avrdude.exe: Version 6.3, compiled on Feb 17 2016 at 09:25:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:WinAVR-20100110binavrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude.exe: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\.libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude.exe: programmer operation not supported
avrdude.exe: Using SCK period of 10 usec
CMD: [ac 53 00 00] [ac 52 53 00]
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | CMD: [30 00 00 00] [00 30 00 1e]
CMD: [30 00 01 00] [00 30 00 95]
################CMD: [30 00 02 00] [00 30 00 0f]
################################## | 100% 0.01s
avrdude.exe: Device signature = 0x1e950f (probably m328p)
avrdude.exe done. Thank you.
The AVRDUDE command line I am using:
avrdude -c usbtiny -p m328p -v -v -v -u flash:w:Test.hex:i
