Fuji X-E2s flash
DaveOls
p.1 #1 · p.1 #1 · Fuji X-E2s flash
I have been using my fairly new Fuji without the flash mostly. I can't seem to find how to change the flash setting to Auto Flash or Forced flash. I have looked in the manual on p 36 and it says to pop up the flash and push the F5 button. I can find the F7 button and the Q button, but the F5 does not seem to work.
I have the camera set to A, but it does not flash when the light is poor. I must be doing something wrong, but I don't know what.
Any suggestions?
Dec 30, 2017 at 07:59 PM
David_Taylor
p.1 #2 · p.1 #2 · Fuji X-E2s flash
Turn "silent mode" off.
Jan 03, 2018 at 07:50 PM
dp13
p.1 #3 · p.1 #3 · Fuji X-E2s flash
Under the shooting menu, item 4, go to flash set up and choose the option you want, auto, forced, slow synch, 2nd curtain synch, commander, or suppressed. It couldn't hurt to read the manual.
Jan 05, 2018 at 06:45 AM
DaveOls
p.1 #4 · p.1 #4 · Fuji X-E2s flash
Thanks for the suggestions. I haven't read the manual because the print is so small that you almost need to use a magnifying glass to see it.
I guess that I will try to download it to my Kindle so I can change the print size.
Jan 05, 2018 at 01:54 PM
DaveOls
p.1 #5 · p.1 #5 · Fuji X-E2s flash
I got the flash to go off in the forced flash mode and also in the Auto mode if the object was dark enough to need flash.
Thanks for the help.
Jan 05, 2018 at 02:55 PM
