Kit Laughlin Offline Upload & Sell: On
@moosehead: changing to an SSD will completely rejuvenate that old MBP; I think you will be amazed, actually. I have done the same upgrade for many friends, pros and amateurs alike, and all rave over the difference.
Whether the extra RAM will make a discernible difference will depend on your ordinary workflow: if your method is to have many large files open at the same time, then yes, but if not, then probably no. It's a simple change (8 > 16, as is the SSD swap).
I have only had good service from macsales dot com (OWC), and their tutorial videos are thorough. The less expensive SSDs they sell ("3G" vs "6G", from memory) are slightly slower, but you save some money and compared to your current drive, all SSDs are Ferraris!
