arduluth Offline Upload & Sell: Off
p.1 #13 · p.1 #13 · Lightweight all manual lens wide angle lens for A6000 | |
The problem with lenses 16-18mm is that unless they're APS-C, they're going to be big. The CV 15/4.5 is the big exception, but that's possible because it's a slow RF lens. Performance is generally going to be worse than you could achieve with a 16-18mm lens designed for APS-C.
Maybe a 24-28mm lens along with a lens turbo would be worth a try? That can come with its own performance issues, but it seems worth your consideration.
The Sony E 16mm f/2.8 is a fully electronic lens. There's no sense in taping the contacts - you won't be able to focus or change aperture. If you can live with AF, there's this lens and there's also Sony E 16/2.8, the Sony E 20/2.8, Sigma 19/2.8, and Sigma 16/1.4. The Sigma 19/2.8 is probably the best lens out of this bunch, but the 16/1.4 is new and might be a very nice lens.
If you're good with something wider, the Samyang 12/2 would be the perfect choice. This is a lot wider, giving the FOV of an 18mm on FF.
