AdaptedLenses Offline Upload & Sell: On
Honestly not really sure about 600 vs 685. Just that the 600’s have worked for me. Might be about TTL? I use manual almost exclusively anyway.
Probably a settings issue. You have to hit the Group button to cycle through the remote groups. I think it shouldn’t flash but I’ll have to test and my flashes are currently on loan. When one is in master mode you hit Group to cycle through groups A, B, C and M(aster). Try cycling to Master, change Mode to off, the cycle to whatever group and try the power?
moosehead222 wrote:
Man, I was going for the TT685s or as you said the V860IIS. I actually prefer the AA's as I have rechargeable envelop pro which have been great as I do not need the extra short recharge time.
Why are the TT600's so low? vs. TT685s which are not really bad. I assume just older model. I can compare the specs when I am ready. I would have missed this so I really appreciate it. I want light, light, so I would have still gone for a couple TT350's.
B&H is so good, I received them today... menu is easy... I do not have a camera yet but everything worked... except, Question >>>> when I tested the Master and turned off its flash, it still flashed. The slave flashed as desired but the Master did flash also. I assume it was just because I was using the test button vs. on camera....Show more →
