Ai_Print Offline Upload & Sell: Off
J.Marcus Photo wrote:
Well I generally don't print very large. I do want the d850 for a few features, the touch to focus ( I use live view a lot with portrait work so I can frame exactly how I like and not run out of focus points) also for faster focus when using the viewfinder, better focusing in low light....
I just wanted to make sure I wouldn't regret it since I really did have to work on my technique a lot coming from d610 to the 810 to get things sharp with 85 1.4g 105 1.4e and 200f2 wide open.
Right, so it sounds like even if you don't print very large, you still want the best files you can get in terms of technical execution.
Being that as it is, I think you are going to find a disproportionate ratio of required shutter speed to increase in resolution when it comes to getting the best files from the D850. For example, I don't know that I would go below 1/250th of a second with the 105 1.4E to get the most out of both the lens and the 46MP and really prefer /320th or higher. I might get away with 1/200th with a 105 2.5 AIS because of significant difference in weight.
In any case, 6 weeks and several thousand frames later & in my experience, this camera shows the results of less than flawless technique considerably sooner than the D810 does. Count on it.
Again, this is with non-VR glass handheld.
