       2       3              5       6       end
DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Admin
p.1 #1 · p.1 #1 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
DxOmark says the new Sony FE 16-35mm f/2.8 GM lens is a the highest-rated wide-angle zoom ever tested.
"The new Sony FE 16-35mm lens reaches new scoring heights in the category of wide-angle zoom lenses, as well as a category record score for Sharpness both when compared to other E-mount lenses and to what is possible with high-end lenses for other mounts. When shot on the Sony A7R II body, it scores 42 Overall, with a Sharpness score of 34. Obviously some of the strength of its results is due to the quality of the Sony A7R II body we used for testing, but it requires a top-of-the-line lens to bring the best out of a top-notch camera body."
Read entire review at DxOmark.com
___________
Help support FM by using our links for your purchase! - Thank you!
Sony FE 16-35mm f/2.8 GM:
B&H Photo | Adorama
_______________
FE 16-35mm f/2.8 GM Main features:
  1. Two Extra-Low Dispersion Elements
  2. Three Aspherical and Two XA Elements
  3. Nano AR and Fluorine Coatings
  4. Two Direct Drive SSM AF Groups
  5. Focus Hold Button, AF/MF Switch
  6. Angle of View: 107 - 63
  7. Minimum Focus Distance 11.02" (28 cm)
  8. Magnification: 0.62x
  9. Elements/Groups: 16 / 13
  10. Dust and Moisture-Resistant Construction
  11. Eleven-Blade Circular Diaphragm
  12. Filter Thread: 82 mm
  13. Dimensions (DxL): Approx. 3.48 x 4.79" (88.5 x 121.6 mm)
  14. Weight: 1.50 lb (680 g)
Canon 16-35/2.8L III on 5DSR vs Sony 16-35/2.8 GM on A7RII
Oct 13, 2017 at 03:45 PM
Messier77
p.1 #2 · p.1 #2 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Looks like they managed to snag a good copy for testing.
I'd pay a big premium ($3000) to purchase their test copy or another known excellent copy. See my long-lived and unloved WTB post. http://www.fredmiranda.com/forum/topic/1507642
Oct 13, 2017 at 03:49 PM
Schlotkins
p.1 #3 · p.1 #3 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Damn that is pretty impressive stuff right there...
Oct 13, 2017 at 03:52 PM
Admin
p.1 #4 · p.1 #4 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
LensRentals' optical bench differ on the results. Perhaps the 16-35GM performs better at closer distances?
Oct 13, 2017 at 03:54 PM
GMPhotography
p.1 #5 · p.1 #5 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
OMG the wars are about to begin. Im taking vacation.
Oct 13, 2017 at 04:12 PM
molson
p.1 #6 · p.1 #6 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
The big question is... how many copies do you have to try to get a good one?
A good marketing campaign by Sony might be "buy five, get one sharp"
Oct 13, 2017 at 04:29 PM
Messier77
p.1 #7 · p.1 #7 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
100% true. I would like this post 10 times if it were possible.
Oct 13, 2017 at 04:32 PM
Blakehfreeman
p.1 #8 · p.1 #8 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Quitter, I'm getting popcorn out and am going to watch this show from the sidelines! *hides under desk*
Mark K
p.1 #9 · p.1 #9 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Have been convincing myself to get the 12-24...and this...
Oct 13, 2017 at 04:34 PM
Mark K
p.1 #10 · p.1 #10 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
GMPhotography
p.1 #11 · p.1 #11 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Ill send the butter over. Lol
Oct 13, 2017 at 04:36 PM
mttran
p.1 #12 · p.1 #12 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
It is a easy to tell a bad/good lens from milc platform but not always from a dslr. This is why we see many oof threads in canikon forums
Oct 13, 2017 at 04:42 PM
molson
p.1 #13 · p.1 #13 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
That's fine if you live in NYC and can walk into B&H and sample all of their copies until you find a good one.
Where I live, I have to order any gear I want, and it takes a week or two to get to me (plus the same amount of time - and cost - shipping back a return). It takes a long time and a lot of money to separate the rare good Sony lenses from the bad ones, which is one of the main reasons I gave up on Sony.
Oct 13, 2017 at 05:00 PM
mttran
p.1 #14 · p.1 #14 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
^^^ but how we fix the unpredictable flapping mirror(s) that causes most oof in dslr regardless good or bad lenses.
Oct 13, 2017 at 05:09 PM
Wanny
p.1 #15 · p.1 #15 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Pretty insane results, my copy is so good though. I didn't think it would beat the Canon by that much
Oct 13, 2017 at 05:12 PM
bjornthun
p.1 #16 · p.1 #16 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Popcorn + Netflix is much more fun.
Oct 13, 2017 at 05:35 PM
mttran
p.1 #17 · p.1 #17 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Out of the lab, realtime MTF is often better with higher precision system platform that defined by MILC not DSLR.
Oct 13, 2017 at 05:39 PM
Gary Clennan
p.1 #18 · p.1 #18 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Doesn't surprise me one bit. This is the best WA zoom lens I have ever used. I'm also gonna buy a lottery ticket today as my copy is bang on perfect.
Oct 13, 2017 at 05:55 PM
Admin
p.1 #19 · p.1 #19 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
If you copy is indeed perfect, it's already worth $3,000!
http://www.fredmiranda.com/forum/topic/1512663/0#14214721
Oct 13, 2017 at 05:57 PM
Holger
p.1 #20 · p.1 #20 · DxOmark: FE 16-35mm f/2.8 GM, Highest-rated wide-angle zoom
Your comments get weirder every time.
My DSLRs deliver. My A9, too. I recommend workshops showing you how to get sharp images with DSLRS. Not that difficult.
- Edited-
Oct 13, 2017 at 06:09 PM
       2       3              5       6       end
       2       3              5       6       end
