Wide Angle Lens - Need Help
MiRunner
p.1 #1 · p.1 #1 · Wide Angle Lens - Need Help
I just bought a D7500 with the 16-80. I want a wide angle, but totally confused(I知 reading too many reviews)😳 I thought I had this figured out but I don稚.. I was looking at the Tokina 11-16mm, Sigma 10-20mm, Tamron 10-24mm, Nikon 10-20mm or Nikon 10-24mm. Im looking at something used, for landscapes and occasionally inside, which the Tokina 11-16mm f2.8 probably is better low light. The Nikon 10-20mm seems to be the worse for IQ out of the bunch. As far as my budget used I壇 like to keep it between $300-$450. I really like the 10mm perspective.is there another lens or some sort of a prime I知 not looking at? My my concern is IQ. Thank you
Edited on Oct 02, 2017 at 11:55 AM · View previous versions
Oct 02, 2017 at 11:39 AM
sjms
p.1 #2 · p.1 #2 · Wide Angle Lens - Need Help
you forgot the Tokina 11-20/2.8. The update to the 11-16/2.8
I had the Tokina 11-16 and it is a very usable lens. I went to the 11-20 for a bit more range and overlap to minimize swapping out with the 16-80
Oct 02, 2017 at 11:44 AM
ckcarr
p.1 #3 · p.1 #3 · Wide Angle Lens - Need Help
One thing about lens reviews, even the worst lens is usually a better performer than the shooter. Get the one you can afford, and learn to shoot properly with it. UWA lenses can be a little tricky.
I'm out of the DX loop (although I did just pick up a D500 Saturday) but have had the Sigma 10-20mm, and both the Nikon 10-24mm and the Nikon 12-24mm. My concern was more the "Now what?" as far as what to shoot, not edges...
Oct 02, 2017 at 01:04 PM
MiRunner
p.1 #4 · p.1 #4 · Wide Angle Lens - Need Help
Thank you, Did you have the 11-16mm II or original version. Yes, I forgot about the Tokina 11-20mm.
Oct 02, 2017 at 01:27 PM
MiRunner
p.1 #5 · p.1 #5 · Wide Angle Lens - Need Help
Congrats on the D500. Thank you. Out of your 3-WA lens, which do you use most ?
Oct 02, 2017 at 01:29 PM
sjms
p.1 #6 · p.1 #6 · Wide Angle Lens - Need Help
11-16 II both are excellent lenses
  NIKON D7000    11.0-16.0 mm f/2.8 lens    11mm    1/60s    6400 ISO    0.0 EV
  NIKON D7000    11.0-16.0 mm f/2.8 lens    11mm    1/15s    6400 ISO    0.0 EV
  NIKON D7200    11.0-20.0 mm f/2.8 lens    13mm    1/160s    100 ISO    0.0 EV
Oct 02, 2017 at 01:39 PM
ckcarr
p.1 #7 · p.1 #7 · Wide Angle Lens - Need Help
I don't own any anymore.
The Nikon 10-20mm is a budget lens, and would be expected to be the worst (although that is not always the case, sometimes Nikon hit's home runs like the 50mm f/1.8G).
If I were to buy another for my D500, which I won't since that's not the mission with it, it would be to find a pristine Nikon 12-24mm. I just prefer OEM lenses in general, and Japanese made if/when possible. Not that there's anything wrong with the others, I just don't use... Except my Sigma 150-600mm Sport..
If you could swing it, I saw the Nikon 10-24mm as a refurb at Adorama but it was $649 and out of your range. And, actually you could probably find a clean used copy here for less.
Oct 02, 2017 at 02:36 PM
MalbikEndar
p.1 #8 · p.1 #8 · Wide Angle Lens - Need Help
You've got 6 options already. You want more?
Oct 02, 2017 at 04:10 PM
MiRunner
p.1 #9 · p.1 #9 · Wide Angle Lens - Need Help
. Thank you.
Oct 02, 2017 at 05:43 PM
Unclejoe1116
p.1 #10 · p.1 #10 · Wide Angle Lens - Need Help
I have the Tokina 11-20, and it is a fantastic lens.
It's solid, it's heavy, it's got brilliant optics, and I've been able to coax an 18-point star out of it at times. Absolutely brilliant lens, built to last, and solid all-around. I've tried a few different wide-angle lenses, and have yet to find something with this build quality at this price. Got mine on eBay for $480.
Also, as a future-proof, I currently have a D750. I am still using this lens in the 16-20 range, because I'm too poor to upgrade to the Tamron 15-30 yet.
Oct 03, 2017 at 01:33 PM
MiRunner
p.1 #11 · p.1 #11 · Wide Angle Lens - Need Help
Thank you. I知 watching a couple on eBay along with a 11-16mm II. Thanks again for the review
Oct 03, 2017 at 02:40 PM
Unclejoe1116
p.1 #12 · p.1 #12 · Wide Angle Lens - Need Help
I'd personally recommend against the 11-16, just because it's not as usable if you ever go full-frame.
I never thought I'd go full-frame. My camera equipment largely gathered dust for several years while I was in school and the two years after, but now that I've started back up again, not having to buy a wide-angle right off the bat for my D750 has helped immensely. (I put that money towards a 70-200 instead.)
I shoot real estate now, and regularly use the 16-20mm range on my full-frame. Personally, I stick closer to 18mm, just to reduce the amount of falloff, but you can sneak pretty close to 16mm before it really starts to vignette.
Oct 04, 2017 at 07:07 PM
