sjms Offline Upload & Sell: On
p.1 #5 · p.1 #5 · Screw Clamp vs Lever Clamp / RRS BH-40 vs Uniqball UBH 35X | |
gregfountain wrote:
The Uniqball has some pretty cool features, as mentioned above, but when I sold my Canon gear in favor of the XT2, I found it a bit overkill, so I sold it and bought the BH-40. Mine has a lever clamp, which I have no issues with, but if you plan on using knock-off L-plates, be advised that even the screw clamp may not hold it tight. I had a knock-off lens foot plate that I used with my 70-200/2.8L IS that would slip in the screw clamp that I had at the time, and I ended up having to add gaffers tape on the rails to prevent the camera and lens from sliding around in the plate.
[/quote
your issue with even a screw clamp slipping is interesting so even the plate wedge angles were off too. sad....Show more →
Edited on Sep 28, 2017 at 08:24 AM · View previous versions
