XQD card to iPad
anthonysemone
p.1 #1 · p.1 #1 · XQD card to iPad
Anyone found a solution for transferring D500 Raw files to my iPadPro ver.1 from an XQD card? I'm in Cape Cod next week. I know I can just use my SD and dongle. I don't know if there exists such a connector for XQD. TIA
Sep 25, 2017 at 08:47 PM
ELinder
p.1 #2 · p.1 #2 · XQD card to iPad
All the XQD card readers need more power than provided by the standard USB connection cables, so unless you want to plug your camera into one of those, you need the Lightning to USB3 Camera Adapter. Plug your XQD reader into that and any power into the USB3 mini-plug
https://www.apple.com/shop/product/MK0W2AM/A/lightning-to-usb-3-camera-adapter?fnode=91&fs=f%3Dadapter%26fh%3D4588%252B45b0
Erich
Sep 25, 2017 at 09:54 PM
CanadaMark
p.1 #3 · p.1 #3 · XQD card to iPad
I use the above posted adapter and it works, however I am using an iPad Pro 10.5" and a CF/SD reader. You also need to plug in external power (the iPad charger) to the adapter/dongle. I can't see why any of that would be different with an older iPad Pro or with XQD, but do note that you will be limited to USB 2.0 transfer speeds on the previous generation iPad Pros.
So what you would do is plug your chosen XQD reader into the female USB port on the adapter, and then plug your iPad charger into the lightning connector on the adapter. Then plug the adapter itself into the iPad and it should work just like your current SD adapter. Not a very 'clean' solution, but it works.
Sep 25, 2017 at 10:04 PM
webmstrk9
p.1 #4 · p.1 #4 · XQD card to iPad
@Elinder is correct, I was using that in combination with the Sony XQD/SD reader for a road trip I was recently on for the iPad Pro 10.5 I have.
Sep 25, 2017 at 10:21 PM
anthonysemone
p.1 #5 · p.1 #5 · XQD card to iPad
You guys are great thanks so very much
Sep 25, 2017 at 11:04 PM
