AmbientMike Offline Upload & Sell: Off
I use Standard with the sharpness turned up almost all the way. I turn up saturation and color tone, too, on my body.
If the lighting is soft, I might turn contrast down less than usual, or leave it at 0, which is still quite a bit, imo.
On the 5D, if you didn't turn sharpness up, in jpeg, you lost a lot of detail compared to raw. Not sure if the 5DII is the same, but I'd want to turn up the sharpness.
Faithful might kill the colors, at least it does on my body, with everything at 0. Could kill sharpness, too.
Some bodies give better results in jpeg, although raw,processors vary, and could change that result.
