Question on OCF:
rollsman4
p.1 #1 · p.1 #1 · Question on OCF:
I sometimes bounce my Strobe off the walls/ Ceiling behind me when I shoot groups and the lighting is beautiful. Of course I use a hi ISO, about ISO 1000-1200. My questions is: What if the walls are NOT white? I am presuming that I can't use this method in that case due to possible color shift from the colored wall. Does anyone shoot this way and with a colored wall? Thank you
Sep 12, 2017 at 12:18 AM
rico
p.1 #2 · p.1 #2 · Question on OCF:
If your fill is low or color-matched to the bounced key, simply apply WB in your usual way.
Sep 12, 2017 at 12:35 AM
kaplah
p.1 #3 · p.1 #3 · Question on OCF:
If the walls are neutral (white to black) you can bounce, althoiugh I can assure you that almost nothing returns from a black wall or ceiling.
A somewhat off-neutral wall will still work, but if it is significantly off-neutral it won't (one supposes you could do a custom profile with a colorchecker passport, but there would be limits to that as well). At which point you can bring out an umbrella, or tape a large piece of white paper / Bristol board to the wall and carry on.
Sep 12, 2017 at 01:21 PM
Steve Wylie
p.1 #4 · p.1 #4 · Question on OCF:
The principle here is that any light source picks up the color of things it bounces off of. That's why portraits made in a grassy field or in a forest usually have a green cast to the skin tones. Same with colored walls.
Sep 12, 2017 at 11:55 PM
rollsman4
p.1 #5 · p.1 #5 · Question on OCF:
Thank you everyone. I wanted to be sure . I will use my Soft box in this situation. Dennis
Sep 14, 2017 at 11:25 AM
Elijah
p.1 #6 · p.1 #6 · Question on OCF:
I come across this during weddings ALL the time.
In these situations, I have my assistant quickly grab my Profoto B2, slap on a Gitzo monopod and an Elinchrom Deep 27.5" octa and gets into position and I just fire away.
But yes, in most cases, ceiling or wall bounce is the best way to go.
Sometimes I even go crazy like bounce off of someone who has a white shirt, cloth, etc.
Sep 22, 2017 at 02:44 AM
Michael White
p.1 #7 · p.1 #7 · Question on OCF:
You can use a skyline frame with a white vinyl fabric over these areas to bounce your light off
Oct 30, 2017 at 09:43 AM
