Bob Jarman Offline Upload & Sell: Off
I tried to embed one image in the other and then mask for the darker sky however ii generally turned out a mess without masking using the pen tool to make a cutout - which I'm not good at. The fundamental difficulty is the two images, as is, will not register - transforming, skewing, etc. to no avail to make them fit properly.
That said, seems if you have the opportunity for a daylight shot, then, without moving anything, getting the sun flare image, or several to make sure, you can then embed one in the other and mask out that which is not needed.
If that is what you are after, I don't know?
Bob
