millsart Offline Upload & Sell: Off
p.1 #3 · p.1 #3 · Anyone remove the right strap lug from the XT2 ?? | |
I don't think mine are that large, but I tend to have the issue with most any camera with side mounted strap lugs.
Its just a flawed design in my mind, having the lug, much less the strap, basically in the same location as where you index finger needs to be to hit the shutter.
On cameras with a larger front grip, and the shutter button relocated more forward, like a typical DSLR its not as bad, but with top plate mounted shutters, its always in the way for me.
I stopped using camera straps through the lugs and instead use a sling style strap attached to the tripod socket. The normal strap placement just results in essentially having to squeeze the strap between my 1st and 2nd fingers.
I just think the whole side there should be totally smooth so people of various hand sizes all have something flat to comfortably grab onto
