ken.vs.ryu Offline Upload & Sell: Off
p.1 #2 · p.1 #2 · x1d firmware 1.17.2 offers electronic shutter. | |
Nikon F lenses on the X1D by Ming Thein
Nikon F mount lenses tested so far on Hasselblad X1D, with rough performance assessment
Zeiss Otus 28/1.4 APO Distagon ZF.2: Does not cover at any aperture; centre 135 format area remains very good but corners are not.
Zeiss Otus 55/1.4 APO Distagon ZF.2: Covers at all apertures but heavy vignetting that does not improve much even on stopping down. Pronounced field curvature outside the 135 format area, and some focus shift. Centre area remains excellent.
Zeiss Otus 85/1.4 APO Planar ZF.2: Covers at all apertures with correctable vignetting at larger apertures. Edges perform much better than expected. Recommended
Zeiss 2/135 APO Sonnar ZF.2 (and Milvus): Covers at all apertures with minor correctable vignetting at larger apertures. Excellent across the frame but tricky to focus due to DOF. Recommended
Zeiss Milvus 1.4/50 Distagon ZF.2: Surprisingly, better coverage than the Otus 55 with less vignetting at the edges, somewhat lower field curvature. Decent centre performance wide open comes close to but not surpasses the Otus 55; edge performance is a little lower but still usable even wide open. For the moment, I actually prefer this to the Otus 55 because cross-frame consistency seems a bit better, but more testing is required.
Zeiss Milvus 1.4/85 Planar ZF.2: Much like the Otus 85: Performs pretty much as it does on smaller formats. Recommended.
Zeiss Contax Yashica 2.8/85 MMG (Leitax modified mount): Surprisingly, this one punches above its weight class. Smooth/lower contrast rendition at f2.8, but really excellent by f5.6. And the tiny size is something else.
Nikon PCE (24, 45, 85) series: All excellent, but you have no aperture control other than to preset aperture with a Nikon body, use the stop down button, unmount and then remount the lens. You’ll even have some shift ability left with all lenses.
Nikon AI 45/2.8 P: Full coverage, minor vignetting, a little bit soft at infinity; good for portraits and decent by f5.6.
Sigma 20/1.4 Art: Here’s a curious one: no aperture control again, but I suspect if you cut the built in hood off, it will cover the full image circle or very close to it.
Voigtlander 180/4 APO-Lanthar: A hidden gem – excellent at all apertures, with microcontrast increasing as you stop down (resolution is already extremely high). Just like a 250 Superachromat, only a little shorter and faster (but much smaller)....Show more →
https://blog.mingthein.com/2017/08/24/e-shutter-firmware-for-the-hasselblad-x1d/
