       2       3       end
Replacement foot Sony FE 100-400 GM Kirk
MedicineMan404
p.1 #1 · p.1 #1 · Replacement foot Sony FE 100-400 GM Kirk
I'm using a RRS replacement foot for the FE100-400GM that is intended for the
FE 70-200/2.8 GM.
Some may prefer a replacement foot that is 'designated' for the big zoom-
https://www.photoproshop.com/Lens-Gear/Lens-Replacement-Feet/Kirk-LP-65-Sony-FE-100-400mm-F4-5-5-6-GM-OSS.html
Aug 22, 2017 at 09:51 AM
Parariss
p.1 #2 · p.1 #2 · Replacement foot Sony FE 100-400 GM Kirk
FE 70-200/2.8 GM.
What does this foot give you that the stock foot does not?
Thx
Aug 22, 2017 at 02:04 PM
bjornthun
p.1 #3 · p.1 #3 · Replacement foot Sony FE 100-400 GM Kirk
Thx
The dovetail on the foot is Arca Swiss compatible, which the Sony dovetail is not.
Aug 22, 2017 at 02:14 PM
gatorine
p.1 #4 · p.1 #4 · Replacement foot Sony FE 100-400 GM Kirk
The Kirk model is also a "double" dovetail.
Not only can the ball head clamp on the bottom of the rail, but a flash bracket Like the Kirk Telephoto Flash Bracket can clamp on the top side of the plate.
This allows the flash to stay in a fixed orientation independent of the lens.
Aug 22, 2017 at 04:56 PM
gatorine
p.1 #5 · p.1 #5 · Replacement foot Sony FE 100-400 GM Kirk
Kirk offers the same model (LP-65) for both the 70-200 GM and the 100-400 GM.
I looked at the RRS 70-200 GM plate, but it was a bit shorter, and I don't think it had the double dovetail. The longer plate allows for more adjustment forward and backward in the clamp for balance if you happen to use a gimbal mount or a Wimberley Sidekick.
Aug 22, 2017 at 05:00 PM
MedicineMan404
p.1 #6 · p.1 #6 · Replacement foot Sony FE 100-400 GM Kirk
The Kirk looks good indeed.
Another feature of the replacement feet are the 'skelatonized' holes that allow use of security systems
like the Op/Tek system Uni Loop-
https://www.amazon.com/OP-TECH-USA-1301062-Uni-Loop/dp/B0010HA6A6/ref=sr_1_17?ie=UTF8&qid=1503721767&sr=8-17&keywords=op%2Ftech+strap
I have one part of the loop through the replacement foot and the other onto the Kirk Security Strap. Just piece of mind.
I've also found that on the RRS foot cited above I still have room for my Cotton Carrier camera hub/room still available for tripod use.
Aug 26, 2017 at 04:32 AM
freaklikeme
p.1 #7 · p.1 #7 · Replacement foot Sony FE 100-400 GM Kirk
Kirk's a US company with their own online storefront...
https://www.kirkphoto.com/lens-mounting/sony/100-400mm-f-4-5-5-6-fe-gm-oss.html
It's significantly cheaper to shop there if you're in the US.
Aug 26, 2017 at 04:48 AM
scrappydog
p.1 #8 · p.1 #8 · Replacement foot Sony FE 100-400 GM Kirk
I attach Op/Tech uniloops to my plates and lock them in to my sling strap before handling my camera. This is a really useful product, especially for klutzes like me.
Aug 26, 2017 at 05:02 AM
Admin
p.1 #9 · p.1 #9 · Replacement foot Sony FE 100-400 GM Kirk
From that page, why not just get the Lens Plate instead of the Replacement lens foot?
Aug 26, 2017 at 05:03 AM
MedicineMan404
p.1 #10 · p.1 #10 · Replacement foot Sony FE 100-400 GM Kirk
Scrappy I've never heard of the Kirk Security Strap failing, the strap itself is probably like a car seatbelt and rated for 1000 pounds. The plate attachment screw has never been reported as having failed either as far as I can tell but screws can unscrew! The Op-Tech is super cheap insurance.
Fred I admit to being a bit vain. The replacement foot just looks a cleaner solution to my eye whether its Kirk or RRS. I went with RRS only because I've used them for years on the Canons.
Aug 26, 2017 at 06:30 AM
Admin
p.1 #11 · p.1 #11 · Replacement foot Sony FE 100-400 GM Kirk
The RRS version also seems to be 15 grams lighter. (so they are almost the same weight)
Aug 26, 2017 at 04:21 PM
scrappydog
p.1 #12 · p.1 #12 · Replacement foot Sony FE 100-400 GM Kirk
Yes it is! Before I had one, I misconnected my sling strap/clamp to my dovetail plate and watched my A7R2 and Canon 100-400 fall to the pavement. Ever since, I have used the Op/Tech clips.
Aug 26, 2017 at 09:02 PM
scrappydog
p.1 #13 · p.1 #13 · Replacement foot Sony FE 100-400 GM Kirk
The plate is cheaper, but the replacement foot is smaller (in height, because you stack the plate on the existing foot) and will weigh less overall. I use a RRS foot on my Canon 500/4 II and it makes it easier to put in the bag than if I had stacked a plate on the default Canon foot.
Aug 26, 2017 at 09:04 PM
virtualrain
p.1 #14 · p.1 #14 · Replacement foot Sony FE 100-400 GM Kirk
Why not replace the foot with a plate? No stacking. That would be even lower profile and lighter.
Aug 27, 2017 at 08:40 AM
scrappydog
p.1 #15 · p.1 #15 · Replacement foot Sony FE 100-400 GM Kirk
I just tried this with my Canon 100-400. The plate would probably fit on with a little space between the lens rings and the top of the plate, but the space is really small. If it worked, the trade-off is that you would not be able to adjust the tighten ring nor the focus ring from the bottom of the lens where the plate is. I noticed that my default movements to adjust those rings include sliding my hand to the bottom of the lens for torque. This would be hampered if I attached the plate directly without a foot. With the foot attached, there is enough of a gap to slide your fingers to the bottom of the lens to adjust the rings. So, for me, it wouldn't be worth the weight advantage or the smaller size to omit the foot, but it may be viable for some.
Aug 27, 2017 at 11:34 AM
Admin
p.1 #16 · p.1 #16 · Replacement foot Sony FE 100-400 GM Kirk
That's exactly how I have mine set-up.
I removed the OEM foot and use my 1.5"x1.5" ($5) Arca Swiss compatible plate directly on the lens. It only weighs 10 grams (8 times less than the foot) and I have full access to all rings and buttons.
Aug 27, 2017 at 03:57 PM
kimknapp
p.1 #17 · p.1 #17 · Replacement foot Sony FE 100-400 GM Kirk
virtualrain:
That looks good. The only problem I see is with gimbals or ballheads like the Acratech, which can be used like gimbals, you want to be able to mount to the center of gravity when the zoom is extended. On mine, with the A6300, that is approximately where the black zoom ring starts. Even with a foot, I found that I was at the end of the plate that I had attached to the foot.
Kim
Aug 27, 2017 at 04:13 PM
MedicineMan404
p.1 #18 · p.1 #18 · Replacement foot Sony FE 100-400 GM Kirk
That 1.5x1.5 plate looks great!
How does i do as a walking handle?
I'm often carrying mine by the RRS replacement foot.
And on the 1.5 x 1.5 I can't see if there is a hole for my
Op/Tech Uni loop.
Aug 27, 2017 at 11:49 PM
Admin
p.1 #19 · p.1 #19 · Replacement foot Sony FE 100-400 GM Kirk
Op/Tech Uni loop.
Mine is similar to this one:
https://www.amazon.com/Fotasy-LP25-Release-Fujifilm-Panasonic/dp/B00OGZKXDY/ref=sr_1_3?ie=UTF8&qid=1503878607&sr=8-3&keywords=small%2Bquick%2Brelease%2Bplate&th=1
But as you can see from the link there are other sizes
Aug 28, 2017 at 12:05 AM
Admin
p.1 #20 · p.1 #20 · Replacement foot Sony FE 100-400 GM Kirk
I also use this lens collapsible lens hood on my 100-400:
https://www.amazon.com/gp/product/B002K4IFY2/ref=oh_aui_detailpage_o03_s00?ie=UTF8&th=1
It extends to the same length as the OEM hood but weighs 3X less.
The collapsible hood + 1.5"x1.5" plate connected directly to the lens save about 135 grams in weight!
Aug 28, 2017 at 12:19 AM
       2       3       end
       2       3       end
