Best Telephoto for Fuji GFX
transientgolf
p.1 #1 · p.1 #1 · Best Telephoto for Fuji GFX
I am in the process of building a Fuji 50s / GFX kit. I am generally sticking with the native lenses but would like one longer lens (which obviously has to be adapted right now). Ideally I would like something in the 300--400 range. I would love any perspectives on what works best here overall. Anyone thoughts?
Thanks!
Aug 20, 2017 at 12:27 AM
Steve Spencer
p.1 #2 · p.1 #2 · Best Telephoto for Fuji GFX
Thanks!
I think the best is the Hasselblad CFE 350 f/5.6 Super Acromat, but it is very expensive. You might looks at the at the Pentax 645 A* 300 f/4 ED and the Pentax 67 M* 400 f/4 ED as more affordable and still very good alternatives.
Aug 20, 2017 at 04:09 AM
transientgolf
p.1 #3 · p.1 #3 · Best Telephoto for Fuji GFX
Thanks. I was looking at the Pentax and curious if there are any other good alternatives out there. Sounds like that is the way to go. Appreciate the response.
Aug 22, 2017 at 01:18 PM
wilco23
p.1 #4 · p.1 #4 · Best Telephoto for Fuji GFX
In 300mm there is Mamiya 645 300/2.8 APO. You can also look at Contax 645 350mm/4 too.
Here is the review for Mamiya http://brianhirschfeldphotography.com/2012/08/21/mamiya-300mm-f2-8-apo-lens-review-with-sample-images-and-comparisons/
Aug 22, 2017 at 01:49 PM
Lee Saxon
p.1 #5 · p.1 #5 · Best Telephoto for Fuji GFX
Fuji is apparently releasing a 180/3.5 for the system, if you need autofocus. And who knows, that's already farther out than I expected them to push for such a small system, at least so soon, so maybe they'll go even longer one day.
Aug 22, 2017 at 04:04 PM
zhangyue
p.1 #6 · p.1 #6 · Best Telephoto for Fuji GFX
If adapting lens, I think there is no dog in Nikon long glass. You want G instead of E type though. I am not exact sure about coverage as I never pay attention to long glass, but seems general speaking: tele lenses usually have better coverage than wide.
And since you are not seek AF, there were also AIS nikon to choose.
Aug 22, 2017 at 04:25 PM
Lee Saxon
p.1 #7 · p.1 #7 · Best Telephoto for Fuji GFX
Disagree about getting Nikon G glass. Like someone was suggesting in the other thread, sure you *can* carry around a Nikon body to preset the aperture on, but I could not be less enthusiastic about that if I tried. Nikon Ai-S is the better suggestion.
However, Nikon D might be an even better idea. There are D versions of the 300/2.8 and 400/2.8 which are newer optical designs than the Ai-S versions but they still have aperture rings. They also have AF-S which of course you won't utilize but I don't think that really matters. Sadly there is no D version of the 200/2.
Of course we don't know for sure that these lenses will cover "miniMF," but at such long focal lengths one can hope.
Aug 23, 2017 at 05:38 AM
Steve Spencer
p.1 #8 · p.1 #8 · Best Telephoto for Fuji GFX
You can control the aperture of G, D, and of course Ai-S lenses when adapted to the GFX. It is only the newest E lenses for which there is not yet an adapter that control the aperture. With the G lenses you don't get marked aperture stops, but you can control the aperture.
Aug 23, 2017 at 06:05 AM
alundeb
p.1 #9 · p.1 #9 · Best Telephoto for Fuji GFX
Many 300-400mm lenses designed for th 35mm format will cover the 44x33 mm sensor well, with acceptable corner sharpness and low vignetting.
The main issue is various aberrations like CA that tend to increase exponential-like in the extended image circle. That is what you pay for with MF glass, aberrations are kept under control in the whole image circle.
Still, there are many options that may produce satisfactory results.
A small and nice option is the SMC Pentax F* 300mm f/4.5, and I have tested it successfully for coverage with a shift adapter.
Aug 23, 2017 at 08:12 AM
SoulNibbler
p.1 #10 · p.1 #10 · Best Telephoto for Fuji GFX
I'll do a quick back to back with the Mamiya 300mm options tonight if you want what focal distance are you interested in infinity or about 5-20meters?
<a data-flickr-embed="true" href="https://www.flickr.com/photos/china-experience/albums/72157685445628860" title="Mamiya 300mm f5.6 vs Mamiya 300mm f2.8 on Fuji GFX"><img src="https://farm5.staticflickr.com/4413/35960709213_edca293890_c.jpg" width="800" height="600" alt="Mamiya 300mm f5.6 vs Mamiya 300mm f2.8 on Fuji GFX"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
link another way:
https://flic.kr/s/aHsm3frNtw
Looks like there is no strong CA in either lens, the sharpness falloff is not dramatic at the edges. The F2.8 version seems to always have a bit more acuity.
Edited on Aug 24, 2017 at 05:06 AM · View previous versions
Aug 23, 2017 at 09:52 AM
suteetat
p.1 #11 · p.1 #11 · Best Telephoto for Fuji GFX
I tried Nikon 300/4e PF and 500/4e FL. The lens will cover GFX sensor with some vignette in the corner, typical of any Nikon lenses adapted to GFX. Center sharpness is not an issue and is I think as good as using it on any FF dslr. However, with 500/4e [email protected], you will need to crop down to about 40mp, keeping 4:3 ratio to get rid off most vignette. I would say that to maximize benefit of GFX, for tele, going with MF lens would be preferable. Unfortunately, I don't have anything longer than 150/3.2 HC at the moment. 300/4e PF is really good for its price and well worth it for the weight alone. Small amount of vignette in the corner is the price but at the same time, sharpness is not in the same league as Fuji 110/2, 120/4 or Hasselblad 150/3.2 HC for sure.
Aug 23, 2017 at 11:12 AM
