GMPhotography Offline Upload & Sell: On
p.1 #2 · p.1 #2 · Sony 12-24 Big Bronco/ STC IR-CUT 64 ND Filter and CPL filter Tests | |
Couple other little tech notes. They say lay the camera on its back to remove screen. Which I agree with but in the field testing you don't want to take camera off tripod and do that so I did it in its normal position on tripod. Have left hand under the mount to catch the baby being born setup.
Now I could not use my finger nail to pop it off once on. So I used a wood toothpick and that made it easy to get it into the slot and pop it off. So in essence camera never moved between on and off. I know I have talent in areas i never knew.
Second and this one is a big. Don't know why they did this but they put written type on the frame . So you would think that should face you. WRONG it actually faces inside towards the sensor. Kind of stupid if you ask me. But you insert the bottom first than push the top of the frame in and text should face the sensor. You want the glass as close to the sensor as possible, remember this
