Wedding Resource List
Godox 860 II's....loose hotshoe connectors
dsouzl
p.1 #1 · p.1 #1 · Godox 860 II's....loose hotshoe connectors
I've been using these flashes for a while now and have noticed that the hotshoe connectors loosen after a bit of usage. I've actually had the flash unit separate from the base during a wedding pretty much destroying the flash.
I've got about 10 of these flashes....and the bases are loose on 3 or 4 of them now.
Has anyone else seen this?
Any idea on how to fix this?
Not sure if imbeded video works, but here's a clip of what I'm talking about...
Video Clip
Aug 12, 2017 at 02:17 PM
dsouzl
p.1 #2 · p.1 #2 · Godox 860 II's....loose hotshoe connectors
Update: I posted this in a Godox FB group. Apparently this is quite common. It looks like I need to either replace the bases...or find and tighten some loose screws.
Aug 12, 2017 at 02:39 PM
glort
p.1 #3 · p.1 #3 · Godox 860 II's....loose hotshoe connectors
Tighten the screws and put a drop of superglue, nail polish or locktite on them.
They won't come loose again. Only need to go through them and fix them once and they will be good forever.
Aug 12, 2017 at 02:58 PM
Tony Hoffer
p.1 #4 · p.1 #4 · Godox 860 II's....loose hotshoe connectors
I have always carried a set of small screwdrivers with me. This has happened a few times and it's a super easy fix as others said above
Aug 12, 2017 at 03:04 PM
dsouzl
p.1 #5 · p.1 #5 · Godox 860 II's....loose hotshoe connectors
Awesome...thanks guys! I unscrewed the bases and tightened the screws inside....and they're not wobbly anymore. Will order some locktite and do this again.
Aug 12, 2017 at 03:47 PM
GumaRodak
p.1 #6 · p.1 #6 · Godox 860 II's....loose hotshoe connectors
I had something similar i believe. When it became loose, i disassebled the hot shoe part, there are little screws which were loose inside. I tightened them and secured with pattex glue as a prevention... from that time its ok
Aug 13, 2017 at 03:41 PM
tomrock
p.1 #7 · p.1 #7 · Godox 860 II's....loose hotshoe connectors
Are you talking about the four screws you can see on the base?
Aug 14, 2017 at 08:08 PM
dsouzl
p.1 #8 · p.1 #8 · Godox 860 II's....loose hotshoe connectors
Tomrock....yes....and no.
You need to unscrew the 4 screws to open the base....after you open the base, you'll see 4 smaller screws going the other way into the hotshoe assembly.
These are the 4 screws you need to tighten.
Aug 16, 2017 at 02:57 AM
BSPhotog
p.1 #9 · p.1 #9 · Godox 860 II's....loose hotshoe connectors
I basically just disassemble these when new and apply locktite to the hot shoe screws from the start.
Aug 16, 2017 at 11:46 AM
tomrock
p.1 #10 · p.1 #10 · Godox 860 II's....loose hotshoe connectors
Thanks. I'll have a look.
Aug 16, 2017 at 09:46 PM
