RRS L Bracket for E-M1 Mk11?
Michael Gordon
p.1 #1 · p.1 #1 · RRS L Bracket for E-M1 Mk11?
New cam on the way to my house. I almost always like an L bracket. It seems the vertical piece can interfere with the full range of motion of the LCD. The RRS vertical piece at least can be removed and I think moved away a bit to allow for more LCD movement. I am unsure of how much inference with the full LCD movement the vertical piece causes. I am wondering whether to get it or just the base piece. Appreciate any comments.
Aug 02, 2017 at 08:30 PM
bobbytan
p.1 #2 · p.1 #2 · RRS L Bracket for E-M1 Mk11?
I got the base plate only because the $100 vertical plate is expensive - relative to the base plate.
When shooting verticals (which I don't do very often on a tripod) I would just flip the camera sideways on the ballhead.
One nice touch by Olympus is that they place the remote port/connector on the opposite side of the camera - separate from all the other ports.
I wonder why it's taking so long for the generic L-plates to hit the market.
Edited on Aug 02, 2017 at 11:17 PM · View previous versions
Aug 02, 2017 at 08:51 PM
DanBrown
p.1 #3 · p.1 #3 · RRS L Bracket for E-M1 Mk11?
I got the RRS L-bracket. I still like to turn the camera itself to change the orientation. YMMV.
Aug 02, 2017 at 08:55 PM
fishjump
p.1 #4 · p.1 #4 · RRS L Bracket for E-M1 Mk11?
I too have the RRS L-bracket, and normally leave the "L" part off (only using it when shooting pano's).
Aug 02, 2017 at 10:38 PM
Michael Gordon
p.1 #5 · p.1 #5 · RRS L Bracket for E-M1 Mk11?
Appreciate the comments. How badly does the vertical piece interfere? I have read some vertical pieces on rrs L brackets can just be moved out a bit w/o removing to allow more freedom of movement. Would be a pain to remove and reattach repeatedly, I think. Thanks.
Aug 03, 2017 at 11:08 PM
DanBrown
p.1 #6 · p.1 #6 · RRS L Bracket for E-M1 Mk11?
What do you mean by "freedom of movement"? What are you wanting to move?
Aug 04, 2017 at 03:11 AM
Michael Gordon
p.1 #7 · p.1 #7 · RRS L Bracket for E-M1 Mk11?
The tiltable swivel LCD screen range of motion is reportedly reduced. Thanks.
Aug 04, 2017 at 11:40 AM
ELinder
p.1 #8 · p.1 #8 · RRS L Bracket for E-M1 Mk11?
Yes, it does limit the movement a somewhat, but in vertical orientation the slot in the L bracket helps. Go to the RRS website and click on the photos. If you scroll sideways thru them there are photos of the screen in various positions with the L bracket in place and also pulled out to the side to give more room.
Erich
Aug 04, 2017 at 02:22 PM
DanBrown
p.1 #9 · p.1 #9 · RRS L Bracket for E-M1 Mk11?
Here's a photo showing how far you can open the lcd screen with the RRS L-bracket in place. There is a hex key held in place by magnets that allows for quick removal of the side plate if needed.
Aug 04, 2017 at 09:40 PM
Michael Gordon
p.1 #10 · p.1 #10 · RRS L Bracket for E-M1 Mk11?
Thanks! The images tell the story.
Aug 05, 2017 at 05:23 PM
